path: root/board/freescale/mpc8568mds/bcsr.h
2008-01-09MPC8568E-MDS: reset UCCs to use them reliablyAnton Vorontsov
In order to use GETH1 and GETH2 on the MPC8568E-MDS, we should reset UCCs. p.s Similar code exists in the Linux kernel board file (for capability reasons with older U-Boots), but should be removed some day. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2007-12-11Move the MPC8568 MDS board under board/freescale.Kumar Gala
Minor path corrections needed to ensure buildability. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
