path: root/board/freescale/mpc8541cds
2014-09-24MAINTAINERS: comment out invalid maintainersMasahiro Yamada
The "S: Orphan" in MAINTAINERS means that the maintainer in the "M:" field is unreachable (i.e. the email address is not working). (Refer to the definition of "Orphan" adopted in U-Boot in the log of commit 31f1b654b2f395b69faa5d0d3c1eb0803923bd3b, "boards.cfg: move boards with invalid emails to Orphan") For patch files adding global changes, scripts/get_maintainer.pl adds bunch of such invalid email addresses, which results in tons of annoying bounce emails. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e ' /^M:[[:blank:]]/ { N /S:[[:blank:]]Orphan/s/^/#/ } ' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-20powerpc: Fix CamelCase checkpatch warningsPrabhakar Kushwaha
85xx, 86xx PowerPC folders have code variables with CamelCase naming conventions. because of this code checkpatch script generates "WARNING: Avoid CamelCase". Convert variables name to normal naming convention and modify board, driver files with updated the new structure. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2012-08-23mpc85xx: use LCRR_DBYP define instead of raw constantPaul Gortmaker
Using the raw value of 0x80000000 directly in the code can lead to "count the zeros" bugs like that fixed in commit 718e9d13b98 ("MPC85xxCDS: Fix missing LCRR_DBYP bits for 66-133MHz LBC") Change all existing raw values to use the symbolic value of LCRR_DBYP instead. Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-01-11MPC85xxCDS: Fix missing LCRR_DBYP bits for 66-133MHz LBCPaul Gortmaker
These boards were meaning to deploy this value: #define LCRR_DBYP 0x80000000 but were missing a zero, and hence toggling a bit that lands in an area marked as reserved in the 8548 reference manual. According to the documentation, LCRR_DBYP should be used as: PLL bypass. This bit should be set when using low bus clock frequencies if the PLL is unable to lock. When in PLL bypass mode, incoming data is captured in the middle of the bus clock cycle. It is recommended that PLL bypass mode be used at frequencies of 83 MHz or less. So the impact would most likely be undefined behaviour for LBC peripherals on boards that were running below 83MHz LBC. Looking at the actual u-boot code, the missing DBYP bit was meant to be deployed as follows: Between 66 and 133, the DLL is enabled with an override workaround. In the future, we'll convert all boards to use the symbolic DBYP constant to avoid these "count the zeros" problems, but for now, just fix the impacted boards. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-03powerpc/mpc85xxcds: Fix PCI speedchenhui zhao
The CDS uses PCICLK as SYSCLK. The PCICLK should be 33333333Hz or 66666666Hz. Signed-off-by: Ebony Zhu <ebony.zhu@freescale.com> Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Refactor fsl_ddr_get_spd into common code from boardKumar Gala
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards pretty much do the same thing. The only variations are in how many controllers or DIMMs per controller exist. To make this work we standardize on the names of the SPD_EEPROM_ADDRESS defines based on the use case of the board. We allow boards to override get_spd to either do board specific fixups to the SPD data or deal with any unique behavior of how the SPD eeproms are wired up. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Replace fsl_ddr_get_mem_data_rate with get_ddr_freq()Kumar Gala
Every 85xx board implements fsl_ddr_get_mem_data_rate via get_ddr_freq() and every 86xx board uses get_bus_freq(). If implement get_ddr_freq() as a static inline to call get_bus_freq() we can remove fsl_ddr_get_mem_data_rate altogether and just call get_ddr_freq() directly. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14MPC8xxx DDR: align informational printsBecky Bruce
Add spaces to cause the informational prints to line up with the ones from init_func_ram() in board.c. Output now looks like this: .... DRAM: Detected 4096 MB of memory This U-Boot only supports < 4G of DDR You could rebuild it with CONFIG_PHYS_64BIT DDR: 2 GiB (DDR2, 64-bit, CL=5, ECC off) .... The prints from lbc_sdram_init() have also been modified to line line up and changed to start with "LBC SDRAM" instead of the confusing "SDRAM". Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14mpc85xx: rename sdram_init() lbc_sdram_init()Becky Bruce
sdram_init() is used to initialize sdram on the lbc. Rename it accordingly. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14mpc85xx boards: initdram() cleanup/bugfixBecky Bruce
Correct initdram to use phys_size_t to represent the size of dram; instead of changing this all over the place, and correcting all the other random errors I've noticed, create a common initdram that is used by all non-corenet 85xx parts. Most of the initdram() functions were identical, with 2 common differences: 1) DDR tlbs for the fixed_sdram case were set up in initdram() on some boards, and were part of the tlb_table on others. I have changed them all over to the initdram() method - we shouldn't be accessing dram before this point so they don't need to be done sooner, and this seems cleaner. 2) Parts that require the DDR11 erratum workaround had different implementations - I have adopted the version from the Freescale errata document. It also looks like some of the versions were buggy, and, depending on timing, could have resulted in the DDR controller being disabled. This seems bad. The xpedite boards had a common/fsl_8xxx_ddr.c; with this change only the 517 board uses this so I have moved the ddr code into that board's directory in xpedite517x.c Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-14fsl: Clean up printing of PCI boot infoPeter Tyser
Previously boards used a variety of indentations, newline styles, and colon styles for the PCI information that is printed on bootup. This patch unifies the style to look like: ... NAND: 1024 MiB PCIE1: connected as Root Complex Scanning PCI bus 01 04 01 8086 1010 0200 00 04 01 8086 1010 0200 00 03 00 10b5 8112 0604 00 02 01 10b5 8518 0604 00 02 02 10b5 8518 0604 00 08 00 1957 0040 0b20 00 07 00 10b5 8518 0604 00 09 00 10b5 8112 0604 00 07 01 10b5 8518 0604 00 07 02 10b5 8518 0604 00 06 00 10b5 8518 0604 00 02 03 10b5 8518 0604 00 01 00 10b5 8518 0604 00 PCIE1: Bus 00 - 0b PCIE2: connected as Root Complex Scanning PCI bus 0d 0d 00 1957 0040 0b20 00 PCIE2: Bus 0c - 0d In: serial ... Signed-off-by: Peter Tyser <ptyser@xes-inc.com> CC: wd@denx.de CC: sr@denx.de CC: galak@kernel.crashing.org
2010-07-1683xx/85xx/86xx: LBC register cleanupBecky Bruce
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code dedicated to defining and manipulating the LBC registers. Merge this into a single spot. To do this, we have to decide on a common name for the data structure that holds the lbc registers - it will now be known as fsl_lbc_t, and we adopt a common name for the immap layouts that include the lbc - this was previously known as either im_lbc or lbus; use the former. In addition, create accessors for the BR/OR regs that use in/out_be32 and use those instead of the mismash of access methods currently in play. I have done a successful ppc build all and tested a board or two from each processor family. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Move to a common linker scriptKumar Gala
There are really no differences between all the 85xx linker scripts so we can just move to a single common one. Board code is still able to override the common one if need be. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Remove redudant PLATFORM_CPPFLAGSKumar Gala
For historic reasons we had defined some additional PLATFORM_CPPFLAGS like: PLATFORM_CPPFLAGS += -DCONFIG_E500=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC85xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8548=1 However these are all captured in the config.h and thus redudant. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-3085xx: Use common LSDMR defines from asm/fsl_lbc.hKumar Gala
2009-01-2385xx: Introduce CONFIG_SYS_PCI*_MEM_VIRT for FSL boardsKumar Gala
Introduce a new define to seperate out the virtual address that PCI memory is at from the physical address. In most situations these are mapped 1:1. However any code accessing the bus should use VIRT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2008-12-19mpc8xxx: LCRR[CLKDIV] is sometimes five bitsTrent Piepho
On newer CPUs, 8536, 8572, and 8610, the CLKDIV field of LCRR is five bits instead of four. In order to avoid an ifdef, LCRR_CLKDIV is set to 0x1f on all systems. It should be safe as the fifth bit was defined as reserved and set to 0. Code that was using a hard coded 0x0f is changed to use LCRR_CLKDIV. Signed-off-by: Trent Piepho <tpiepho@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-10-18Pass dimm parameters to populate populate controller optionsHaiying Wang
Because some dimm parameters like n_ranks needs to be used with the board frequency to choose the board parameters like clk_adjust etc. in the board_specific_paramesters table of the board ddr file, we need to pass the dimm parameters to the board file. * move ddr dimm parameters header file from /cpu to /include directory. * add ddr dimm parameters to populate board specific options. * Fix fsl_ddr_board_options() for all the 8xxx boards which call this function. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-08-27FSL DDR: Convert MPC8541CDS to new DDR code.Jon Loeliger
Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-10mpc85xx: workaround old binutils bugKumar Gala
The recent change to move the .bss outside of the image gives older binutils (ld from eldk4.1/binutils-2.16) some headache: ppc_85xx-ld: u-boot: Not enough room for program headers (allocated 3, need 4) ppc_85xx-ld: final link failed: Bad value We workaround it by being explicit about the program headers and not assigning the .bss to a program header. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-31mpc85xx: Update linker scripts for Freescale boardsKumar Gala
* Move to using absolute addressing always. Makes the scripts a bit more portable and common * Moved .bss after the end of the image. These allows us to have more room in the resulting binary image for code and data. * Removed .text object files that aren't really needed * Make sure _end is 4-byte aligned as the .bss init code expects this. (Its possible that the end of .bss isn't 4-byte aligned) Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-1185xx/86xx: Move to dynamic mgmt of LAWsKumar Gala
With the new LAW interface (set_next_law) we can move to letting the system allocate which LAWs are used for what purpose. This makes life a bit easier going forward with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
2008-06-1185xx: remove dummy board_early_init_fKumar Gala
A number of board ports have empty version of board_early_init_f for no reason since we control its via CONFIG_BOARD_EARLY_INIT_F. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-1185xx: Remove unused and unconfigured memory test code.Kumar Gala
Remove unused and unconfigured DDR test code from FSL 85xx boards. Besides, other common code exists. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-26FSL: Clean up board/freescale/common/MakefileJon Loeliger
Each file that can be built here now follows some CONFIG_ option so that they are appropriately built or not, as needed. And CONFIG_ defines were added to various board config files to make sure that happens. The other board/freescale/*/Makefiles no longer need to reach up and over into ../common to build their individually needed files any more. Boards that are CDS specific were renamed with cds_ prefix. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-05Remove erroneous or extra spd.h #includers.Jon Loeliger
Many of the spd.h #includers don't need it, and wanted to have spd_sdram() declared instead. Since they didn't get that, some also had open coded extern declarations of it instead or as well. Fix it all up by using spd_sdram.h where needed. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-1785xx: Convert MPC8541/MPC8555/MPC8548 CDS to new TLB setupKumar Gala
2008-01-1685xx: Use proper defines for PCI addressesKumar Gala
We should be using the _MEM_PHYS for LAW and TLB setup and not _MEM_BASE. While _MEM_BASE & _MEM_PHYS are normally the same, _MEM_BASE should only be used for configuring the PCI ATMU. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1685xx: convert MPC8541/MPC8555/MPC8548 CDS over to use new LAW init codeKumar Gala
2008-01-09Reworked FSL Book-E TLB macros to be more readableKumar Gala
The old macros made it difficult to know what WIMGE and perm bits were set for a TLB entry. Actually use the bit masks for these items since they are only a single bit. Also moved the macros into mmu.h out of e500.h since they aren't specific to e500. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
