With the new LAW interface (set_next_law) we can move to letting the
system allocate which LAWs are used for what purpose. This makes life
a bit easier going forward with the new DDR code.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Acked-by: Jon Loeliger <jdl@freescale.com>
Acked-by: Becky Bruce <becky.bruce@freescale.com>
A number of board ports have empty version of board_early_init_f
for no reason since we control its via CONFIG_BOARD_EARLY_INIT_F.
Remove unused and unconfigured DDR test code from FSL 85xx boards.
Besides, other common code exists.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
The cross compiler is responsible for providing the correct libraries
and the logic to find the linking libraries.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Each file that can be built here now follows some
CONFIG_ option so that they are appropriately built
or not, as needed. And CONFIG_ defines were added
to various board config files to make sure that happens.
The other board/freescale/*/Makefiles no longer need
to reach up and over into ../common to build their
individually needed files any more.
Boards that are CDS specific were renamed with cds_ prefix.
When we go to 36-bit physical addresses we need to keep the concept of
the physical CCSRBAR address seperate from the virtual one.
For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR
Many of the spd.h #includers don't need it,
and wanted to have spd_sdram() declared instead.
Since they didn't get that, some also had open
coded extern declarations of it instead or as well.
Fix it all up by using spd_sdram.h where needed.
We should be using the _MEM_PHYS for LAW and TLB setup and not _MEM_BASE.
While _MEM_BASE & _MEM_PHYS are normally the same, _MEM_BASE should only
be used for configuring the PCI ATMU.
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
The old macros made it difficult to know what WIMGE and perm bits
were set for a TLB entry. Actually use the bit masks for these items
since they are only a single bit.
Also moved the macros into mmu.h out of e500.h since they aren't specific
to e500.
Minor path corrections needed to ensure buildability.
