path: root/board/freescale/mpc8541cds
2008-08-27FSL DDR: Convert MPC8541CDS to new DDR code.Jon Loeliger
Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-10mpc85xx: workaround old binutils bugKumar Gala
The recent change to move the .bss outside of the image gives older binutils (ld from eldk4.1/binutils-2.16) some headache: ppc_85xx-ld: u-boot: Not enough room for program headers (allocated 3, need 4) ppc_85xx-ld: final link failed: Bad value We workaround it by being explicit about the program headers and not assigning the .bss to a program header. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-31mpc85xx: Update linker scripts for Freescale boardsKumar Gala
* Move to using absolute addressing always. Makes the scripts a bit more portable and common * Moved .bss after the end of the image. These allows us to have more room in the resulting binary image for code and data. * Removed .text object files that aren't really needed * Make sure _end is 4-byte aligned as the .bss init code expects this. (Its possible that the end of .bss isn't 4-byte aligned) Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-1185xx/86xx: Move to dynamic mgmt of LAWsKumar Gala
With the new LAW interface (set_next_law) we can move to letting the system allocate which LAWs are used for what purpose. This makes life a bit easier going forward with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
2008-06-1185xx: remove dummy board_early_init_fKumar Gala
A number of board ports have empty version of board_early_init_f for no reason since we control its via CONFIG_BOARD_EARLY_INIT_F. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-1185xx: Remove unused and unconfigured memory test code.Kumar Gala
Remove unused and unconfigured DDR test code from FSL 85xx boards. Besides, other common code exists. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-26FSL: Clean up board/freescale/common/MakefileJon Loeliger
Each file that can be built here now follows some CONFIG_ option so that they are appropriately built or not, as needed. And CONFIG_ defines were added to various board config files to make sure that happens. The other board/freescale/*/Makefiles no longer need to reach up and over into ../common to build their individually needed files any more. Boards that are CDS specific were renamed with cds_ prefix. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-05Remove erroneous or extra spd.h #includers.Jon Loeliger
Many of the spd.h #includers don't need it, and wanted to have spd_sdram() declared instead. Since they didn't get that, some also had open coded extern declarations of it instead or as well. Fix it all up by using spd_sdram.h where needed. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-1785xx: Convert MPC8541/MPC8555/MPC8548 CDS to new TLB setupKumar Gala
2008-01-1685xx: Use proper defines for PCI addressesKumar Gala
We should be using the _MEM_PHYS for LAW and TLB setup and not _MEM_BASE. While _MEM_BASE & _MEM_PHYS are normally the same, _MEM_BASE should only be used for configuring the PCI ATMU. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1685xx: convert MPC8541/MPC8555/MPC8548 CDS over to use new LAW init codeKumar Gala
2008-01-09Reworked FSL Book-E TLB macros to be more readableKumar Gala
The old macros made it difficult to know what WIMGE and perm bits were set for a TLB entry. Actually use the bit masks for these items since they are only a single bit. Also moved the macros into mmu.h out of e500.h since they aren't specific to e500. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Move the MPC8541/MPC8555/MPC8548 CDS board under board/freescale.Kumar Gala
Minor path corrections needed to ensure buildability. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
