path: root/board/freescale/mpc8536ds/mpc8536ds.c
2009-09-08ppc/8xxx: Refactor code to determine if PCI is enabled & agent/hostKumar Gala
Refactor the code into a simple bitmask lookup table that determines if a given PCI controller is enabled and if its in host/root-complex or agent/end-point mode. Each processor in the PQ3/MPC86xx family specified different encodings for the cfg_host_agt[] and cfg_IO_ports[] boot strapping signals. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Cleanup whitespace in mpc8536ds.cKumar Gala
2009-08-28pci/fsl_pci_init: Fold fsl_pci_setup_inbound_windows into fsl_pci_initKumar Gala
Every platform that calls fsl_pci_init calls fsl_pci_setup_inbound_windows before it calls fsl_pci_init. There isn't any reason to just call it from fsl_pci_init and simplify things a bit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28pci/fsl_pci_init: Fold pci_setup_indirect into fsl_pci_initKumar Gala
Every platform that calls fsl_pci_init calls pci_setup_indirect before it calls fsl_pci_init. There isn't any reason to just call it from fsl_pci_init and simplify things a bit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2285xx/86xx: Replace in8/out8 with in_8/out_8 on FSL boardsKumar Gala
The pixis code used in8/out8 all over the place. Replace it with in_8/out_8 macros. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2285xx: Report which "bank" of NOR flash we are booting from on FSL boardsKumar Gala
The p2020DS, MPC8536DS, MPC8572DS, MPC8544DS boards are capable of swizzling the upper address bits of the NOR flash we boot out of which creates the concept of "virtual" banks. This is useful in that we can flash a test of image of u-boot and reset to one of the virtual banks while still maintaining a working image in "bank 0". The PIXIS FPGA exposes registers on LBC which we can use to determine which "bank" we are booting out of (as well as setting which bank to boot out of). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-04-04fsl_pci: Move prototypes into fsl_pci.h and remove explicit externsKumar Gala
2009-04-04fsl_pci: Renamed immap_fsl_pci.h to fsl_pci.hKumar Gala
Rename the pci header for FSL HW so we can move some prototypes in there and stop doing explicit externs Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-1685xx: Add eSDHC support for 8536 DSAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-16Fixup SGMII PHY ids in the device treeAndy Fleming
The device tree's PHY addresses need to be fixed up if we're using the SGMII Riser Card. The 8572, 8536, and 8544 DS boards were modified to call this function. Code idea taken from Liu Yu <yu.liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-01-28mpc8536ds.c: include sata.h to for needed function prototypesWolfgang Denk
2009-01-27SATA: do not auto-initialize during bootMike Frysinger
Rather than have the board code initialize SATA automatically during boot, make the user manually run "sata init". This brings the SATA subsystem in line with common U-Boot policy. Rather than having a dedicated weak function "is_sata_supported", people can override sata_initialize() to do their weird board stuff. Then they can call the actual __sata_initialize(). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-2385xx: Convert CONFIG_SYS_PCI*_IO_BASE to _IO_BUS for FSL boardsKumar Gala
Use CONFIG_SYS_PCI*_IO_BUS for the bus relative address instead of _IO_BASE so we are more explicit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-2385xx: Convert CONFIG_SYS_{PCI*,RIO*}_MEM_BASE to _MEM_BUS for FSL boardsKumar Gala
Use CONFIG_SYS_{PCI,RIO}_MEM_BUS for the bus relative address instead of _MEM_BASE so we are more explicit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: separate FLASH BASE virtual from physical addressKumar Gala
Added a CONFIG_SYS_FLASH_BASE_PHYS for use as the physical address and maintain CONFIG_SYS_FLASH_BASE as the virtual address of the flash. This allows us to deal with 36-bit phys on these boards in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2008-12-0385xx: the DDR tlb is missed for the !CONFIG_SPD_EEPROM caseDave Liu
we need TLB entry for DDR at !SPD case. Signed-off-by: Dave Liu <daveliu@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2008-12-0385xx: remove the unused ddr_enable_ecc in the board fileDave Liu
The DDR controller of 8548/8544/8568/8572/8536 processors have the ECC data init feature, and the new DDR code is using the feature, and we don't need the way with DMA to init memory any more. Signed-off-by: Dave Liu <daveliu@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2008-11-02Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-10-2485xx: Convert all fsl_pci_init users to new APIsKumar Gala
Converted ATUM8548, MPC8536DS, MPC8544DS, MPC8548CDS, MPC8568MDS, MPC8572DS, TQM85xx, and SBC8548 to use fsl_pci_setup_inbound_windows() and ft_fsl_pci_setup(). With these changes the board code is a bit smaller and we get dma-ranges set in the device tree for these boards. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com>
2008-10-2185xx: Fix compile warning in mpc8536ds.cKumar Gala
mpc8536ds.c: In function 'is_sata_supported': mpc8536ds.c:615: warning: unused variable 'devdisr' Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-18Enabled the Freescale SGMII riser card on 8536DSJason Jin
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2008-10-1885xx: Improve flash remapping on MPC8572DS & MPC8536DSKumar Gala
Changing the flash from cacheable to cache-inhibited was taking a significant amount of time due to the fact that we were iterating over the full 256M of flash. Instead we can just flush the L1 d-cache and invalidate the i-cache. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-15Fix compiler warning in lib_ppc/board.cHeiko Schocher
Fix compiler warning introduced by commit 0f8cbc18 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-14Do not init SATA when disabled on 8536DS.Jason Jin
SGMII and SATA share the serdes on MPC8536 CPU, When SATA disabled and the driver still try to access the SATA registers, the cpu will hangup. This patch try to fix this by reading the serdes status before the SATA initialize. Signed-off-by: Jason Jin <Jason.jin@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2008-08-27mpc85xx: Add support for the MPC8536DS reference boardKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Signed-off-by: Dejan Minic <minic@freescale.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
