path: root/board/freescale/mpc837xemds
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-09-08net: Merge asm/fsl_enet.h into fsl_mdio.hClaudiu Manoil
fsl_enet.h defines the mapping of the usual MII management registers, which are included in the MDIO register block common to Freescale ethernet controllers. So it shouldn't depend on the CPU architecture but it should be actually part of the arch independent fsl_mdio.h. To remove the arch dependency, merge the content of asm/fsl_enet.h into fsl_mdio.h. Some files (like fm_eth.h) were simply including fsl_enet.h only for phy.h. These were updated to include phy.h instead. Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-04-20fsl: Change fsl_phy_enet_if to phy_interface_tAndy Fleming
The fsl_phy_enet_if enum was, essentially, the phy_interface_t enum. This meant that drivers which used fsl_phy_enet_if to deal with PHY interfaces would have to convert between the two (or we would have to have them mirror each other, and deal with the ensuing maintenance headache). Instead, we switch all clients of fsl_phy_enet_if over to phy_interface_t, which should become the standard, anyway. Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-20tsec: Convert tsec to use PHY LibAndy Fleming
This converts tsec to use the new PHY Lib. All of the old PHY support is ripped out. The old MDIO driver is split off, and placed in fsl_mdio.c. The initialization is modified to initialize the MDIO driver as well. The powerpc config file is modified to configure PHYLIB if TSEC_ENET is configured. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Detlev Zundel <dzu@denx.de>
2010-10-20powerpc/8xxx: Add fdt_fixup_phy_connection helperKumar Gala
Add a common helper that will set the PHY connection type based on enum. We use this on eTSEC, UCC, and will with Fman in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-18mpc83xx: fix 837x MDS PCI HOST buildKim Phillips
commit 6aa3d3bfaa986f1aff5e21a9b9f68d087715b1a9 "83xx: Remove warmboot parameter from PCI init functions" missed one mpc83xx_pcie_init callsite, causing this build error: Configuring for MPC837XEMDS_HOST board... pci.c: In function 'pci_init_board': pci.c:141: error: too many arguments to function 'mpc83xx_pcie_init' this patch extends the commit to include that callsite. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-2383xx: Remove warmboot parameter from PCI init functionsPeter Tyser
This change lays the groundwork for the BOOTFLAG_* flags being removed. This change has the small affect of delaying 100ms on PCI initialization after a warm boot as opposed to the optimal 1ms on some boards. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> included the mpc8308_p1m board. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-04-26ppc: Split MPC83xx SERDES code from MPC85xx/MPC86xx/QorIQKumar Gala
The MPC83xx SERDES control is different from the other FSL PPC chips. For now lets split it out so we can standardize on interfaces for determining of a device on SERDES is configured. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-18mpc83xx: convert all remaining boards over to 83XX_GENERIC_PCIKim Phillips
2009-07-16mpc83xx: MPC837xEMDS: Use hwconfig instead of pci_external_arbiter variableAnton Vorontsov
Since we have simple hwconfig interface now, we don't need pci_external_arbiter variable any longer. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-16mpc83xx: MPC837XEMDS: Fixup eSDHC nodes in device treeAnton Vorontsov
fdt_fixup_esdhc() will either disable or enable eSDHC nodes, and also will fixup clock-frequency property. Plus, since DR USB and eSDHC are mutually exclusive, we should only configure the eSDHC if asked through hwconfig. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-0283xx: Replace CONFIG_ECC_INIT_VIA_DDRC referencesPeter Tyser
Update 83xx architecture's CONFIG_ECC_INIT_VIA_DDRC references to CONFIG_ECC_INIT_VIA_DDRCONTROLLER, which other Freescale architectures use Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-05mpc83xx: MPC837XEMDS: Initialize SerDes before negating PCIE reset signalAnton Vorontsov
The SerDes initialization should be finished before negating the reset signal according to the reference manual. This isn't an issue on real hardware, but we'd better stick to the specifications anyway. Suggested-by: Liu Dave <DaveLiu@freescale.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-1683xx: Add eSDHC support on 8379 EMDS boardAndy Fleming
2009-01-21mpc83xx: Add PCI-E support for MPC837XEMDS boardsAnton Vorontsov
MPC837XEMDS boards can support PCI-E via "PCI-E riser card". The card provides two PCI-E (x2) ports. Though, only one port can be used in x2 mode. Two ports can function simultaneously in x1 mode. PCI-E x1/x2 modes can be switched via "pex_x2" environment variable. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-10-21mpc83xx: add support for switching between USB Host/Function for MPC837XEMDSAnton Vorontsov
With this patch u-boot can fixup the dr_mode and phy_type properties for the Dual-Role USB controller. While at it, also remove #ifdefs around includes, they are not needed. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-10-21mpc83xx: fix PCI scan hang on the standalone MPC837xE-MDS boardsAnton Vorontsov
The MPC837xE-MDS board's CPLD can auto-detect if the board is on the PIB, standalone or acting as a PCI agent. User's Guide says: - When the CPLD recognizes its location on the PIB it automatically configures RCW to the PCI Host. - If the CPLD fails to recognize its location then it is automatically configured as an Agent and the PCI is configured to an external arbiter. This sounds good. Though in the standalone setup the CPLD sets PCI_HOST flag (it's ok, we can't act as PCI agents since we receive CLKIN, not PCICLK), but the CPLD doesn't set the ARBITER_ENABLE flag, and without any arbiter bad things will happen (here the board hangs during any config space reads). In this situation we must disable the PCI. And in case of anybody really want to use an external arbiter, we provide "pci_external_aribter" environment variable. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-10-21mpc83xx: add SGMII riser module support for the MPC8378E-MDS boardsAnton Vorontsov
This involves configuring the SerDes and fixing up the flags and PHY addresses for the TSECs. For Linux we also fix up the device tree. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-10-21mpc83xx: fix serdes setup for the MPC8378E boardsAnton Vorontsov
MPC837xE specs says that SerDes1 has: — Two lanes running x1 SGMII at 1.25 Gbps; — Two lanes running x1 SATA at 1.5 or 3.0 Gbps. And for SerDes2: — Two lanes running x1 PCI Express at 2.5 Gbps; — One lane running x2 PCI Express at 2.5 Gbps; — Two lanes running x1 SATA at 1.5 or 3.0 Gbps. The spec also explicitly states that PEX options are not valid for the SD1. Nevertheless MPC8378 RDB and MDS boards configure the SD1 for PEX, which is wrong to do. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-24mpc83xx: spd_sdram: fix ddr sdram base address assignment bugAnton Vorontsov
The spd_dram code shifts the base address, then masks 20 bits, but forgets to shift the base address back. Fix this by just masking the base address correctly. Found this bug while trying to relocate a DDR memory at the base != 0. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-04-11mpc83xx: Fix the bug of serdes initializationDave Liu
Currently the serdes will not be initializated due to the partid's error. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-28mpc83xx: cleanup System Part and Revision ID Register (SPRIDR) codeKim Phillips
in the spirit of commit 1ced121600b2060ab2ff9f0fddd9421fd70a0dc6, 85xx's "Update SVR numbers to expand support", simplify SPRIDR processing and processor ID display. Add REVID_{MAJ,MIN}OR macros to make REVID dependent code simpler. Also added PARTID_NO_E and IS_E_PROCESSOR convenience macros. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-28mpc83xx: initialize serdes for MPC837xEMDS boardsDave Liu
This patch is stolen from Anton Vorontsov's patch for mpc837xerdb boards. The reference clk and xcorevdd voltage of serdes1/2 is same between mpc837xemds and mpc837xerdb. 8377E: LYNX1- 2 SATA LYNX2- 2 PCIE 8378E: LYNX1- 2 SGMII LYNX2- 2 PCIE 8379E: LYNX1- 2 SATA LYNX2- 2 SATA Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-05Remove erroneous or extra spd.h #includers.Jon Loeliger
Many of the spd.h #includers don't need it, and wanted to have spd_sdram() declared instead. Since they didn't get that, some also had open coded extern declarations of it instead or as well. Fix it all up by using spd_sdram.h where needed. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-08mpc83xx: remove FLAT_TREE codeKim Phillips
need to rm it from pci code, too! Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08mpc83xx: Add the support of MPC837xEMDS boardDave Liu
The MPC837xEMDS board support: * DDR2 400MHz hardcoded and SPD init * Local bus NOR Flash * I2C, UART, MII and RTC * eTSEC RGMII * PCI host Signed-off-by: Dave Liu <daveliu@freescale.com>
