path: root/board/freescale/mpc8360erdk/Makefile
2008-03-25mpc83xx: MPC8360E-RDK: add support for NANDAnton Vorontsov
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-01-10mpc83xx: add support for the MPC8360E-RDKAnton Vorontsov
This is MPC8360E based board with: - 256MB fixed SDRAM; - 8MB Intel Strata NOR flash; - StMICRO 64MiB NAND flash; - two 10/100/1000 ethernet ports connected via Broadcom BCM5481 PHYs; - two 10/100 ethernet ports connected via National DP83848 PHYs; - one PCI and one miniPCI slots; - four serial ports (two NS16550-compatible, two UCCs); - four USB ports working through MPC8360E "FHCI" USB controller; - Fujitsu MB86277 graphics controller; - Analog to Digital Converter/Touchscreen controller, AD7843 connected to SPI. Features not supported in this patch are: - StMICRO 64MiB NAND flash (patch sent); - MINT framebuffer initialization (patch is pending); - Fetching production information from the EEPROM via I2C; - FHCI USB; - Two slow UCCs used as RS-485 UARTs. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
