path: root/board/freescale/mpc8360emds/Makefile
2015-01-23powerpc: mpc83xx: remove MPC8360ERDK, EMPC8360EMDS supportMasahiro Yamada
These boards are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Dave Liu <daveliu@freescale.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
2009-07-18mpc83xx: convert all remaining boards over to 83XX_GENERIC_PCIKim Phillips
2007-08-29support board vendor-common makefilesKim Phillips
if a board/$(VENDOR)/common/Makefile exists, build it. also add the first such case, board/freescale/common/Makefile, to handle building board-shared EEPROM, PIXIS, and MDS-PIB code, as dictated by board configuration. thusly get rid of alternate build dir errors such as: FATAL: can't create /work/wd/tmp/u-boot-ppc/board/freescale/mpc8360emds/../common/pq-mds-pib.o: No such file or directory by putting the common/ mkdir command in its proper place (the common Makefile). Common bits from existing individual board Makefiles have been removed. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-16mpc83xx: move freescale boards to boards/freescaleKim Phillips
includes build fixes. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
