path: root/board/freescale/mpc8349emds/pci.c
2008-08-25MPC8349EMDS: Add PCI Agent (PCISLAVE) supportIra W. Snyder
Add the ability for the MPC8349EMDS to run in PCI Agent mode, acting as a PCI card rather than a host computer. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-08-25MPC8349EMDS: use 83XX_GENERIC_PCI setup codeIra W. Snyder
Change the MPC8349EMDS board to use the generic PCI initialization code for the mpc83xx cpu. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08mpc83xx: rm remaining FLAT_TREE codeKim Phillips
..in board pci.c files Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08mpc83xx: convert to using do_fixup_*()Kim Phillips
convert to using simpler mpc85xx style fdt update code; streamline by eliminating macros OF_SOC, OF_CPU, etc. which allows us to rm the old school FLAT_TREE code from 83xx (since the sbc8349 was just converted over to using libfdt). Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-11-21Update libfdt from device tree compiler (dtc)Kumar Gala
Update libfdt to commit 8eaf5e358366017aa2e846c5038d1aa19958314e from the device tree compiler (dtc) project. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-08-16mpc83xx: move freescale boards to boards/freescaleKim Phillips
includes build fixes. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
