path: root/board/freescale/mpc8323erdb/mpc8323erdb.c
2019-05-21mpc83xx: Get rid of CONFIG_SYS_DDR_BASEMario Six
CONFIG_SYS_DDR_BASE is specific to mpc83xx an is always set to the same value as CONFIG_SYS_SDRAM_BASE. Just use CONFIG_SYS_SDRAM_BASE instead. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2013-07-15PPC MPC83xx: Fix MPC8323ERDB build warningWolfgang Denk
Fix: mpc8323erdb.c: In function 'mac_read_from_eeprom': mpc8323erdb.c:198:3: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Wolfgang Denk <wd@denx.de> cc: Timur Tabi <timur@tabi.org> cc: Kim Phillips <kim.phillips@freescale.com>
2011-07-06powerpc/83xx: remove empty board_early_init_f()Timur Tabi
Remove an empty board_early_init_f() from the MPC8323ERD and MPC360ERDK boards. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-2383xx: Remove warmboot parameter from PCI init functionsPeter Tyser
This change lays the groundwork for the BOOTFLAG_* flags being removed. This change has the small affect of delaying 100ms on PCI initialization after a warm boot as opposed to the optimal 1ms on some boards. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> included the mpc8308_p1m board. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-28mpc8323erdb: fix EEPROM page size and get MAC from EEPROMMichael Barkowski
This patch fixes eeprom page size so that you can now write more than 64 bytes at a time. It also makes the board take MAC addresses, if found, from EEPROM. User should place up to 4 addresses at offset 0x7f00, for eth{,1,2,3}addr. Any unused addresses should be zero. This group of four six-byte values should have it's CRC at the end. crc32 and eeprom commands can be used to accomplish this. If CRC fails, MAC addresses come from the environment. If CRC succeeds, the environment is overwritten at startup. Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-05Remove erroneous or extra spd.h #includers.Jon Loeliger
Many of the spd.h #includers don't need it, and wanted to have spd_sdram() declared instead. Since they didn't get that, some also had open coded extern declarations of it instead or as well. Fix it all up by using spd_sdram.h where needed. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-08mpc83xx: remove FLAT_TREE codeKim Phillips
need to rm it from pci code, too! Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-16mpc83xx: implement board_add_ram_infoKim Phillips
add board_add_ram_info, to make memory diagnostic output more consistent. u-boot banner output now looks like: DRAM: 256 MB (DDR1, 64-bit, ECC on) and for boards with SDRAM on the local bus, a line such as this is added: SDRAM: 64 MB (local bus) also replaced some magic numbers with their equivalent define names. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-15mpc83xx: migrate remaining freescale boards to libfdtKim Phillips
this adds libfdt support code for the freescale mpc8313erdb, mpc832xemds, mpc8349emds, mpc8349itx, and gp boards. Boards remain compatible with OF_FLAT_TREE. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-15mpc83xx: move common /memory node update mechanism to cpu.cKim Phillips
also adds common prototypes to include/common.h. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-10mpc83xx: add support for the MPC8323E RDBKim Phillips
MPC8323E based board with 64MB fixed SDRAM, 16MB flash, five 10/100 ethernet ports connected via an ICPlus IP175C switch, one PCI slot, and serial. Features not supported in this patch are SD card interface, 2 USB ports, and the two phone ports. Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
