path: root/board/freescale/mpc8315erdb
2009-01-21mpc83xx: Add PCI-E support for MPC8315ERDB boardsAnton Vorontsov
MPC8315ERDB boards features PCI-E x1 and Mini PCI-E x1 ports. Let's support them. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-24mpc83xx: spd_sdram: fix ddr sdram base address assignment bugAnton Vorontsov
The spd_dram code shifts the base address, then masks 20 bits, but forgets to shift the base address back. Fix this by just masking the base address correctly. Found this bug while trying to relocate a DDR memory at the base != 0. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-1683xx: mpc8315erdb: fix silly thinko in fdt_tsec1_fixupAnton Vorontsov
The thinko was quite silly indeed, I messed with !ptr. Normally this would trigger some fault, but in U-Boot NULL pointer is equal to phys 0, so the code was working still, just didn't actually test mpc8315erdb environment variable value. Heh. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-07-1683xx: mpc8315erdb: add support for switching between ULPI/UTMI USB PHYsAnton Vorontsov
Freescale ships MPC8315E-RDB boards either with TSEC1 and USB UTMI support, or without TSEC1 but with USB ULPI PHY support in addition. With this patch user can specify desired USB PHY. Also, it seems that we can't distinguish the two boards in software, so user have to set `mpc8315erdb' environment variable to either 'tsec1' (TSEC1 enabled) or `ulpi' (board with ULPI PHY, TSEC1 disabled), so that Linux will not probe for TSEC1. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-16mpc83xx: fix mpc8313/mpc8315/mpc8349itx Makefiles for silent build (with -s)Kumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-16mpc83xx: Add the support for MPC8315ERDB boardDave Liu
The features list: - Boot from NOR Flash - DDR2 266MHz hardcoded configuration - Local bus NOR Flash R/W operation - I2C, UART, MII and RTC - eTSEC0/1 support - PCI host Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
