path: root/board/freescale/mpc8313erdb
2008-03-2583xx: Add Vitesse VSC7385 firmware uploadingTimur Tabi
Update the MPC8349E-mITX, MPC8313E-RDB, and MPC837XE-RDB board files to upload the Vitesse VSC7385 firmware. Changed CONFIG_VSC7385 to CONFIG_VSC7385_ENET. Cleaned up the board header files to make selecting the VSC7385 easier to control. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-16mpc83xx: fix mpc8313/mpc8315/mpc8349itx Makefiles for silent build (with -s)Kumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08mpc83xx: remove FLAT_TREE codeKim Phillips
need to rm it from pci code, too! Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-08-16mpc83xx: move freescale boards to boards/freescaleKim Phillips
includes build fixes. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
