path: root/board/freescale/mpc8308rdb
2019-05-21mpc83xx: Get rid of CONFIG_SYS_DDR_SDRAM_BASEMario Six
CONFIG_SYS_DDR_SDRAM_BASE is set to the same value as CONFIG_SYS_SDRAM_BASE on all existing boards. Just use CONFIG_SYS_SDRAM_BASE instead. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2016-09-27usb: fsl: Rename fdt_fixup_dr_usbSriram Dash
The function fdt_fixup_dr_usb is specific to fsl/nxp. So, make the function name explicit and rename fdt_fixup_dr_usb into fsl_fdt_fixup_dr_usb. Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2012-09-18mpc8308rdb: add support for eSDHC MMC controllerIra W. Snyder
Add support for the onboard eSDHC MMC controller. The hardware on the MPC8308RDB has the following errata: - ESDHC111: manual asynchronous CMD12 is broken - DMA is broken (PIO works) Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> [added include fsl_esdhc header to prevent implicit declarations of fsl_esdhc_mmc_init() and fdt_fixup_esdhc()] Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-09-18mpc8308rdb: add support for Spansion SPI flash on header J8Ira W. Snyder
The SPI pins are routed to header J8 for testing SPI functionality. A Spansion flash has been wired up and tested on this header. This patch breaks support for the second TSEC interface, since the GPIO pin used as a chip select is pinmuxed with some of the TSEC pins. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-2383xx: Remove warmboot parameter from PCI init functionsPeter Tyser
This change lays the groundwork for the BOOTFLAG_* flags being removed. This change has the small affect of delaying 100ms on PCI initialization after a warm boot as opposed to the optimal 1ms on some boards. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> included the mpc8308_p1m board. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-23MPC8308RDB: various clean upsIlya Yanok
This patch cleans up the Freescale MPC8308RDB Development board support. Things fixed: - Removed unused PCIE2 definitions from configuration - SICR{L,H} defines used for System I/O Configuration Registers values instead of hardcoding - CONFIG_SYS_SCCR_PCIEXP1CM used to enable PCIE clock instead of writing to SCCR from the board code - sleep mode stuff removed as MPC8308 has no support for deep sleep and PMCCR1 register. board_early_init_f() removed. - MPC8308 has no ERRATA for DDR controller so workaround removed - 'assignment in if statement' issues solved - use LBLAWAR_* defines instead of hardcoding Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-07-09MPC8308RDB: minimal support for devboard from FreescaleIlya Yanok
This patch provides support for MPC8308RDB development board from Freescale with a minimal set of features: Dual UART is supported NOR flash is supported Both TSEC Ethernet controllers are supported PCI Express initialization is supported The following features are enabled in configuration but not fully tested: I2C (used to get the board revision) I2C-connected RTC VSC7385 switch There is one (hopefully) minor issue: on soft reset the board sometimes resets twice. I've not managed to find the fix for this problem yet. As a workaround instruction cache can be disabled. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
