path: root/board/freescale/mpc7448hpc2
2008-09-02Moved initialization of TSI108 Ethernet controller to board_eth_init()Ben Warren
Affected boards: mpc7448hpc2 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26mpc7448hpc2: Fix PCI I/O space mapping.Randy Vinson
PCI I/O space is currently mapped 1:1 at 0xFA000000. Linux requires PCI I/O space to start at 0 on the PCI bus. This patch maps PCI I/O space such that 0xFA000000 in the processor's address space maps to 0 on the PCI I/O bus. Signed-off-by Randy Vinson <rvinson@mvista.com> Acked-by: Roy Zang <tie-fei.zang@freescale.com>
2008-08-19Clean up usage of icache_disable/dcache_disableKumar Gala
There is no point in disabling the icache on 7xx/74xx/86xx parts and not also flushing the icache. All callers of invalidate_l1_instruction_cache() call icache_disable() right after. Make it so icache_disable() calls invalidate_l1_instruction_cache() for us. Also, dcache_disable() already calls dcache_flush() so there is no point in the explicit calls of dcache_flush(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-11Fix some more printf() format issues.Wolfgang Denk
2008-06-09Remove the deprecated CONFIG_OF_FLAT_TREEGerald Van Baren
Use CONFIG_OF_LIBFDT instead to support flattened device trees. It is cleaner, has better functionality, and is better supported. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2008-06-09Convert mpc7448hpc2 to CONFIG_OF_LIBFDTGerald Van Baren
This was configured to use the deprecated CONFIG_OF_FLAT_TREE, change to CONFIG_OF_LIBFDT. WARNING: This conversion is untested because I do not have a board to test it on. NOTE: The FDT blob (DTS) must have an /aliases/ethernet0 and (optionally) /aliases/ethernet1 property for the ethernet to work. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2008-03-25FSL: Move board/mpc7448hpc2 under board/freescaleJon Loeliger
