path: root/board/freescale/mpc7448hpc2/config.mk
2015-01-16powerpc: 74xx_7xx: remove 74xx_7xx cpu supportMasahiro Yamada
All the 74xx_7xx boards are still non-generic boards: P3G4, ZUMA, ppmc7xx, ELPPC, mpc7448hpc2 Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: York Sun <yorksun@freescale.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2008-03-25FSL: Move board/mpc7448hpc2 under board/freescaleJon Loeliger
