path: root/board/freescale/m548xevb/m548xevb.c
2012-09-20ColdFire: Clean up checkpatch warnings for MCF547x and MCF548xAlison Wang
Signed-off-by: Alison Wang <b18965@freescale.com>
2011-10-19ColdFire: Fix compilation with CONFIG_SYS_DRAMSZ1 definedstany MARCEL
A temp variable was used but not declared, with CONFIG_SYS_DRAMSZ1 defined. This variable is now declared in the functione when needed. Signed-off-by: Stany MARCEL <stany.marcel@novasys-ingenierie.com>
2008-01-17ColdFire: MCF547x_8x - Add M547xEVB and M548xEVB boardTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
