path: root/board/freescale/m5373evb
2011-09-04ColdFire: Cleanup for partial linking and --gc-sectionsJason Jin
Introduce the --gc-sections for ColdFire platform and clean up the corresponding lds file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-04-13m68k: Move cpu/$CPU to arch/m68k/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-03-17ColdFire: Fix M5329EVB and M5373EVB nand issueTsiChung Liew
The Nand flash was unable to read and write properly due to Nand Chip Select (nCE) setup was in reverse order. Also, increase the Nand time out value to 60. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-11-03ColdFire: Fix M5329EVB and M5373EVB nand issueTsiChung Liew
Fix compilation issue caused by a few mismatches. Provide proper nand chip select enable/disable in nand_hwcontrol() rather than in board_nand_init() just enable once. Remove redundant local nand driver functions - nand_read_byte(), nand_write_byte() and nand_dev_ready() to use common nand driver. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-11-03ColdFire: Remove platforms mii.c fileTsiChung Liew
Will use mcfmii.c driver in drivers/net rather than keep creating new mii.c for each future platform. Remove EB+MCF-EV123, cobra5272, idmr, M5235EVB, M5271EVB, M5272C3, M5275EVB, M5282EVB, M5329EVB, M5373EVB, M54451EVB, M54455EVB, M547xEVB, and M548xEVB's mii.c Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-08-13m5373evb: Update NAND driver to new API.Scott Wood
2008-01-17ColdFire: Add M5373EVB platform support - 1TsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
