path: root/board/freescale/m5329evb
2010-04-13m68k: Move cpu/$CPU to arch/m68k/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-03-17ColdFire: Fix M5329EVB and M5373EVB nand issueTsiChung Liew
The Nand flash was unable to read and write properly due to Nand Chip Select (nCE) setup was in reverse order. Also, increase the Nand time out value to 60. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-11-03ColdFire: Fix M5329EVB and M5373EVB nand issueTsiChung Liew
Fix compilation issue caused by a few mismatches. Provide proper nand chip select enable/disable in nand_hwcontrol() rather than in board_nand_init() just enable once. Remove redundant local nand driver functions - nand_read_byte(), nand_write_byte() and nand_dev_ready() to use common nand driver. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-11-03ColdFire: Remove platforms mii.c fileTsiChung Liew
Will use mcfmii.c driver in drivers/net rather than keep creating new mii.c for each future platform. Remove EB+MCF-EV123, cobra5272, idmr, M5235EVB, M5271EVB, M5272C3, M5275EVB, M5282EVB, M5329EVB, M5373EVB, M54451EVB, M54455EVB, M547xEVB, and M548xEVB's mii.c Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-01-17ColdFire: Update FlexBus CS for MCF532xTsiChungLiew
Definition update and change from 16bit to 32bit Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
2007-09-15ColdFire: fix build error becasue of bad type of mii_init()Liew Tsi Chung-r5aahp
2007-08-16ColdFire: MCF5329 Update and cleanupTsiChungLiew
2007-08-08Coding style cleanupStefan Roese
2007-08-08Added NAND supportTsiChungLiew
2007-08-08Moved sync() from board file to include/asm-m68k/io.hTsiChungLiew
2007-08-08Declared attributes of void __mii_init(void) as an alias for int mii_init(void)TsiChungLiew
2007-07-16Coding style cleanupStefan Roese
2007-07-10Update for flash.o and mii.oTsiChungLiew
Removed flash.o and added mii.o Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-07-10MII functions calls.TsiChungLiew
2007-07-10Removed MII functions and replaced immap_5329.h and m5329.h with immap.h.TsiChungLiew
The removed MII routines will be placed in mii.c. Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-07-10Duplicate codeTsiChungLiew
There is a Common Flash Interface Driver existed. To use the CFI driver, define CFG_FLASH_CFI in configuration file. Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-06-18Added M5329AFEE and M5329BFEE PlatformsTsiChung Liew
Added board/freescale/m5329evb, cpu/mcf532x, drivers/net, drivers/serial, immap_5329.h, m5329.h, mcfrtc.h, include/configs/M5329EVB.h, lib_m68k/interrupts.c, and rtc/mcfrtc.c Modified CREDITS, MAKEFILE, Makefile, README, common/cmd_bdinfo.c, common/cmd_mii.c, include/asm-m68k/byteorder.h, include/asm-m68k/fec.h, include/asm-m68k/io.h, include/asm-m68k/mcftimer.h, include/asm-m68k/mcfuart.h, include/asm-m68k/ptrace.h, include/asm-m68k/u-boot.h, lib_m68k/Makefile, lib_m68k/board.c, lib_m68k/time.c, net/eth.c and rtc/Makefile Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
