A lot changed in the Linux MTD code, since it was last ported from
Linux to U-Boot. This patch takes U-Boot NAND support to the level
of Linux 2.6.22.1 and will enable support for very large NAND devices
(4KB pages) and ease the compatibility between U-Boot and Linux
filesystems.
This patch is tested on two custom boards with PPC and ARM
processors running YAFFS in U-Boot and Linux using gcc-4.1.2
cross compilers.
MAKEALL ppc/arm has some issues:
* DOC/OneNand/nand_spl is not building (I have not tried porting
these parts, and since I do not have any HW and I am not familiar
with this code/HW I think its best left to someone else.)
Except for the issues mentioned above, I have ported all drivers
necessary to run MAKEALL ppc/arm without errors and warnings. Many
drivers were trivial to port, but some were not so trivial. The
following drivers must be examined carefully and maybe rewritten to
some degree:
cpu/ppc4xx/ndfc.c
cpu/arm926ejs/davinci/nand.c
board/delta/nand.c
board/zylonite/nand.c
Signed-off-by: William Juul <william.juul@tandberg.com>
Signed-off-by: Stig Olsen <stig.olsen@tandberg.com>
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
The cross compiler is responsible for providing the correct libraries
and the logic to find the linking libraries.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Definition update and change from 16bit to 32bit
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Signed-off by: John Rigby <jrigby@freescale.com>
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
Removed flash.o and added mii.o
The removed MII routines will be placed in mii.c.
There is a Common Flash Interface Driver existed. To use the CFI driver, define CFG_FLASH_CFI in configuration file.
Added board/freescale/m5329evb, cpu/mcf532x, drivers/net,
drivers/serial, immap_5329.h, m5329.h, mcfrtc.h,
include/configs/M5329EVB.h, lib_m68k/interrupts.c, and
rtc/mcfrtc.c
Modified CREDITS, MAKEFILE, Makefile, README, common/cmd_bdinfo.c,
common/cmd_mii.c, include/asm-m68k/byteorder.h, include/asm-m68k/fec.h,
include/asm-m68k/io.h, include/asm-m68k/mcftimer.h,
include/asm-m68k/mcfuart.h, include/asm-m68k/ptrace.h,
include/asm-m68k/u-boot.h, lib_m68k/Makefile, lib_m68k/board.c,
lib_m68k/time.c, net/eth.c and rtc/Makefile
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
