path: root/board/freescale/m5271evb
2014-03-10m68k: Remove M5271EVB and idmr board supportMasahiro Yamada
CONFIG_SYS_HZ must be always 1000, but M5271EVB.h defines it as 1000000 and idmr.h defines it as (50000000 / 64). When compiling these two boards, a warning message is displayed: time.c:14:2: warning: #warning "CONFIG_SYS_HZ must be 1000 and should not be defined by platforms" [-Wcpp] There are no board maintainers for them so this commit just deletes them. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jason Jin <Jason.jin@freescale.com>
2013-11-01m68k: convert makefiles to Kbuild styleMasahiro Yamada
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-19ColdFire: Cleanup lds files for multiple defined symbolsstany MARCEL
Lds files cleened to remove multiple defined section and modified to be compliant with --gc-sections added for ColdFire platform in a previous patch. Signed-off-by: Stany MARCEL <stany.marcel@novasys-ingenierie.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-04-13m68k: Move cpu/$CPU to arch/m68k/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-03-24ColdFire: M5271EVB DRAM Bring up issueTsiChung Liew
Fix proper portsize: The register for portsize is either 00b, 01b, or 1xb. The value that previous assigned is 32d. Fix DRAM bring up: insert asm("nop") for every DRAM register setup Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2008-11-03ColdFire: Remove platforms mii.c fileTsiChung Liew
Will use mcfmii.c driver in drivers/net rather than keep creating new mii.c for each future platform. Remove EB+MCF-EV123, cobra5272, idmr, M5235EVB, M5271EVB, M5272C3, M5275EVB, M5282EVB, M5329EVB, M5373EVB, M54451EVB, M54455EVB, M547xEVB, and M548xEVB's mii.c Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-08-14ColdFire: Move m5271evb from board to board/freescaleTsiChung Liew
