path: root/board/freescale/m5253evbe/Makefile
2018-07-23m68k: m5253evbe: Remove this boardTom Rini
The m5253evbe board has been marked as orphan since June of 2014 and should have been dropped a while ago. Do so now. Signed-off-by: Tom Rini <trini@konsulko.com>
2013-11-01m68k: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jason Jin <Jason.jin@freescale.com>
2007-08-16ColdFire: Add M5253EVBE platform for MCF52x2TsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
