path: root/board/freescale/m5253demo
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop init.h from common headerSimon Glass
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop flash.h from common headerSimon Glass
Move this uncommon header out of the common header. Fix up some style problems in flash.h while we are here. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move testdram() into init.hSimon Glass
This function is called during init so move it to the init header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move enable/disable_interrupts out of common.hSimon Glass
Move these two functions into the irq_funcs.h header file. Also move interrupt_handler_t as this is used by the irq_install_handler() function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-01MAINTAINERS: Switch nxp.com domainFabio Estevam
freescale.com domain is no longer reachable, so switch the maintainers' emails to nxp.com domain instead. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-05-22Kconfig: Add a CONFIG_IDE optionSimon Glass
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate CONFIG_IDE option so that IDE support can be enabled without requiring the 'ide' command. Update existing users and move the ide driver into drivers/block since it should not be in common/. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-12m5253demo: Fix static variable in non-static inline function warningTom Rini
The function 'spin_wheel' is declared as inline, but not static and thus we see warnings that 'w' and 'p' are declared static in a non-static inline function. Correct this by marking spin_wheel as static inline. Cc: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2015-04-23m68k: add architecture-specific u-boot.ldsangelo@sysam.it
Add architecture-specific u-boot.lds and remove all board-specific u-boot.lds. All the .text customization that was board-specific have been moved inside the related include/configs, inside a LDS_BOARD_TEXT define. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2014-07-22m68k: fix an undefined behavior warning of M5253DEMO boardMasahiro Yamada
The latest GCC is so clever that it reports more warnings than old ones did: ------------------------------>8------------------------------ board/freescale/m5253demo/flash.c: In function 'flash_get_offsets': board/freescale/m5253demo/flash.c:65:23: warning: iteration 2047u invokes undefined behavior [-Waggressive-loop-optimizations] info->start[k + 1] = info->start[k] + CONFIG_SYS_SST_SECTSZ; ^ board/freescale/m5253demo/flash.c:64:3: note: containing loop for (k = 0, j = 0; j < CONFIG_SYS_SST_SECT; j++, k++) { ^ ------------------------------8<------------------------------ The cause of the warning is like this: The for statement iterates 2048 times in flash_get_offsets() func. (Notice CONFIG_SYS_SST_SECT is defined as 2048) The last iteration does info->start[2048] = info->start[2047] + CONFIG_SYS_SST_SECTSZ; causing an undefined behavior. (Please note the array size of info->start is 2048. CONFIG_SYS_MAX_FLASH_SECT is defined as 2048 for this board.) This commit fixes that so as not to overrun the info->start array. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jason Jin <Jason.jin@freescale.com>
2014-06-19freescale: m5253demo: fix unused-but-set-variable warningsMasahiro Yamada
Fix the following warning messages: In function 'flash_erase': 180:21: warning: variable 'last' set but not used [-Wunused-but-set-variable] In function 'write_buff': 322:10: warning: variable 'port_width' set but not used [-Wunused-but-set-variable] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2013-11-01m68k: convert makefiles to Kbuild styleMasahiro Yamada
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-09-20ColdFire: Clean up checkpatch warnings for MCF52x2Alison Wang
Signed-off-by: Alison Wang <b18965@freescale.com>
2011-09-04ColdFire:Add mb for 5253 dram initializationJason Jin
The dram initialization sequence should be in order. This patch add mb for the dram intialization code to make sure the compiler do not disorder the code. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ColdFire: Cleanup for partial linking and --gc-sectionsJason Jin
Introduce the --gc-sections for ColdFire platform and clean up the corresponding lds file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-04-13m68k: Move cpu/$CPU to arch/m68k/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-15Convert DM9000 driver for CONFIG_NET_MULTIRemy Bohmer
All drivers need to be converted to CONFIG_NET_MULTI. This patch converts the dm9000 driver. Signed-off-by: Thomas Smits <ts.smits@gmail.com> Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-14ColdFire: Add M5253DEMO platform support for MCF5253TsiChung Liew
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
