path: root/board/freescale/m5235evb/m5235evb.c
2008-07-11ColdFire: Fix power up issue for MCF5235TsiChung Liew
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2007-08-17ColdFire: Add M5235EVB Platform for MCF523xTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
