path: root/board/freescale/m52277evb
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-04-13m68k: Move cpu/$CPU to arch/m68k/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-11-03ColdFire: Add SBF support for M52277EVBTsiChung Liew
Add serial boot support Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-01-17ColdFire: Add MCF5227x cpu and M52277EVB support-1TsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
