path: root/board/freescale/m52277evb/m52277evb.c
2008-11-03ColdFire: Add SBF support for M52277EVBTsiChung Liew
Add serial boot support Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-01-17ColdFire: Add MCF5227x cpu and M52277EVB support-1TsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
