path: root/board/freescale/m5208evbe
2010-04-13m68k: Move cpu/$CPU to arch/m68k/cpu/$CPUPeter Tyser
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-14ColdFire: Add M5208EVB and MCF520x CPU supportTsiChung Liew
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
