path: root/board/freescale/ls2085a/ls2085a.c
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-09-25ARMv8/ls2085a: Enable secondary coresYork Sun
Spin table is at the very beginning of boot code. Each core has an individual release address within the spin table, the ft_cpu_setup fn updates the "cpu-release-addr" property of each cpu node with the corresponding release address. Also fix CPU_RELEASE_ADDR to point to secondary_boot_func. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Arnab Basu <arnab.basu@freescale.com>
2014-09-25ARMv8/ls2085a_emu: Enable DP-DDR as standalone memory blockYork Sun
DP-DDR is used for DPAA, separated from main memory pool for general use. It has 32-bit bus width and use a standard DDR4 DIMM (64-bit). Signed-off-by: York Sun <yorksun@freescale.com>
2014-09-24board/ls2085a: Update env_addr after NOR flash relocationPrabhakar Kushwaha
LS2085a has 2 regions in system memory map. Region1 is default map from where system boots. Once u-boot is moved to DDR, IFC is re-mapped to Region2. So, update gd->env_addr to reflect correct address. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-04ARMv8/ls2085a_emu: Add LS2085A emulator and simulator board supportYork Sun
LS2085A is an ARMv8 implementation. This adds board support for emulator and simulator: Two DDR controllers UART2 is used as the console IFC timing is tightened for speedy booting Support DDR3 and DDR4 as separated targets Management Complex (MC) is enabled Support for GIC 500 (based on GICv3 arch) Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Arnab Basu <arnab.basu@freescale.com> Signed-off-by: J. German Rivera <German.Rivera@freescale.com> Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
