path: root/board/freescale/ls2080ardb
2019-01-17armv8: ls2088ardb: Update MAINTAINERSYork Sun
Signed-off-by: York Sun <york.sun@nxp.com> CC: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2019-01-17fsl-layerscape: dpaa: fix fsl-mc status in fdt with bootefiMian Yousaf Kaukab
fsl-mc lazyapply command applies dpl from efi_exit_boot_services(). Status of fsl-mc node in working fdt is updated at this stage. However, an efi application like grub may already have copied the fdt. So the updates to fdt done at efi_exit_boot_services() may not be visible to the OS. Fix it by updating fdt earlier if fsl-mc lazyapply command is used. Fixes: b7b8410a8f (ls2080: Exit dpaa only right before exiting U-Boot) Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: York Sun <york.sun@nxp.com>
2019-01-17armv8: ls2088ardb: Add TFABOOT supportRajesh Bhagat
TFABOOT support includes: - ls2088ardb_tfa_defconfig to be loaded by trusted firmware - environment address and size changes for TFABOOT - define BOOTCOMMAND for TFABOOT - remove EL3 specific erratas for TFABOOT Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-10-10driver: net: fsl-mc: Add support of multiple phys for dpmacPankaj Bansal
Till now we have had cases where we had one phy device per dpmac. Now, with the upcoming products (LX2160AQDS), we have cases, where there are sometimes two phy devices for one dpmac. One phy for TX lanes and one phy for RX lanes. to handle such cases, add the support for multiple phys in ethernet driver. The ethernet link is up if all the phy devices connected to one dpmac report link up. also the link capabilities are limited by the weakest phy device. i.e. say if there are two phys for one dpmac. one operates at 10G without autoneg and other operate at 1G with autoneg. Then the ethernet interface will operate at 1G without autoneg. Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-09-27u-boot: fixup the iommu-map property of fsl-mc nodeNipun Gupta
The iommu-map property in the fsl-mc node is updated by valid stream-ids by u-boot. This patch is to fixup this property for LS208x and LS1088. Signed-off-by: Nipun Gupta <nipun.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-07-26armv8: ls2080ardb: update copyright claimAlison Wang
This patch updates the copyright claim for the issues reported by legal review. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-06-08board: Kconfig: Re-Arrangement of PPA firmware and header addressesBhaskar Upadhaya
PPA firmware and header address may vary depending upon different boards, configure ppa firmware and header address in board specific Kconfig. Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Signed-off-by: Jagdish Gediya <jagdish.gediya@nxp.com> Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-05-10board/freescale: Remove invalid fsl email addressesFabio Estevam
These fsl email addresses are no longer valid and they do not have a correspondent nxp.com entry. Remove all invalid fsl email addresses and mark the boards as orphan. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-01-30armv8: ls2088ardb: Add 3DS RDIMM supportYork Sun
Tested with MTA72ASS8G72PSZ-2S6G1. This is 3DS RDIMM module with x4 DDR chips. LS2088ARDB needs to be modified to connect all DQS signals. Some of them are grounded by default for x8 chips. Tested with RDIMM MTA18ASF2G72PDZ on main memory controllers. DP-DDR doesn't support RDIMM. Dropped related timing table. Signed-off-by: York Sun <york.sun@nxp.com>
2018-01-15board/ls2081ard: Correct code to get QMAP value in checkboardPriyanka Jain
QMAP value contains information about QSPI chip-selects. These bits are used to display information of boot device in checkboard() function. QMAP value is stored in most significant 3-bits of 8-bit register brdcfg[0] in Qixis, this patch corrects code to get QMAP bits using below logic: (brdcfg[0] >> 5) & 0x7 Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-15board/ls2081ardb: Update board related printsPriyanka Jain
Remove Board Arch print as its value is always constant '1' and does not contain any important information to display during boot. Add print to display Board FPGA version. Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-14board/ls2080a, ls1088a: Add check for mc-dpl applied in fdtYogesh Gaur
Function fdt_fixup_board_enet() performs fdt fixup. Only return fdt_status_okay() when both MC is applied and DPL is deployed, else return fdt_status_fail(). This check is added to LS1088A/LS2080A/LS2088A boards. Signed-off-by: Yogesh Gaur <yogeshnarayan.gaur@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-22board/ls2080ardb: Update board env based on SoCPriyanka Jain
As per current implementation, default value of board env is based on board filename i.e ls2080ardb. With distro support changes, this env is used to decide upon kernel dtb which is different for other SoCs (ls2088a, ls2081a) combination supported with this board. Add support to modify board env at runtime based on SoC type Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-11armv8: LS2080ARDB: Add secure boot defconfig for QSPI boot.Udit Agarwal
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> [YS: dropped redundant commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-11LS2080ARDB: QSPI boot: Secure Boot image validationUdit Agarwal
Adds header address for PPA to be validated during ESBC phase for ARCH_LS2088 and QSPI_BOOT. Moves sec_init prior to ppa_init(). It must be initialized before the PPA. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> [YS: revised commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-09board: ls2080ardb: Add fsl_fdt_fixup_flashSantan Kumar
IFC and QSPI are muxed on board. Add fsl_fdt_fixup_flash() to disable IFC node in dts if QSPI is enabled, or disable QSPI node in dts if otherwise. Signed-off-by: Santan Kumar <santan.kumar@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> [YS: Revise commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-09board:ls2080ardb: Update execution of config_board_muxSantan Kumar
Function config_board_mux() reads env variable 'hwconfig' which is only available after relocation for QSPI boot. Move calling config_board_mux() to misc_init_r(). Signed-off-by: Santan Kumar <santan.kumar@nxp.com> [YS: Revise commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-09board/ls2080ardb: Disable SD-related GPIO programmingSantan Kumar
Smart voltage translator is removed from LS2080ARDB/LS2088ARDB RevF boards. It is only used on LS2081ARDB. Programming GPIO is only required for LS2081ARDB. Signed-off-by: Santan Kumar <santan.kumar@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> [YS: Revise commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2017-06-05common: freescale: Move arch-specific declarationsSimon Glass
The declarations should not be in common.h. Move them to the arch-specific headers. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup thinko defined(FSL_LSCH3) -> defined(CONFIG_FSL_LSCH3)] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-01drivers: net: fsl-mc: Link MC boot to PHY_RESET_RBogdan Purcareata
DPAA2 platforms boot the Management Complex based on the u-boot env variable "mcinitcmd". Instead of doing this step on each platform individually, define a single mc_env_boot function in the MC driver, since it's semantically tied to it. Call the function in a per-board reset_phy hook, as it gets called at a later moment, when all board PHY devices have been initialized. Signed-off-by: Bogdan Purcareata <bogdan.purcareata@nxp.com> Signed-off-by: Heinz Wrobel <heinz.wrobel@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23armv8: LS2080A: Adjust memory map for secure boot headers for NOR-bootUdit Agarwal
This patch adjusts memory map for secure boot headers on LS2080AQDS and LS2080ARDB platforms. Secure boot headers are placed on NOR flash at offset 0x00600000. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23armv8: ls2080ardb, ls2080aqds: Adjust memory map for NOR-bootSantan Kumar
This patch adjusts memory map for images on LS2080ARDB and LS2080AQDS NOR flash as below Image Flash Offset RCW+PBI 0x00000000 Boot firmware (U-Boot) 0x00100000 Boot firmware Environment 0x00300000 PPA firmware 0x00400000 PHY firmware 0x00980000 DPAA2 MC 0x00A00000 DPAA2 DPL 0x00D00000 DPAA2 DPC 0x00E00000 Kernel.itb 0x01000000 Signed-off-by: Santan Kumar <santan.kumar@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23armv8: ls2080ardb: Add LS2081ARDB board supportPriyanka Jain
LS2081ARDB board is similar to LS2080ARDB board with few differences It hosts LS2081A SoC Default boot source is QSPI-boot It does not have IFC interface RTC and QSPI flash device are different It provides QIXIS access via I2C Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Santan Kumar <santan.kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23armv8: ls2080ardb: Add QSPI-boot supportPriyanka Jain
QSPI-boot is supported on LS2088ARDB RevF board with LS2088A SoC. LS2088ARDB RevF Board has limitation that QIXIS can not be accessed. CONFIG_FSL_QIXIS is not enabled. Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Suresh Gupta <suresh.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23board: freescale: ls2080ardb: Update QIXIS codePriyanka Jain
Update QIXIS related code to be executed only if CONFIG_FSL_QIXIS flag is enabled. In case QIXIS code is not enabled, use default sysclk value as 100MHz per board documentation. Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23board: freescale: ls2080ardb: Enable SD interface for RevF boardPriyanka Jain
LS2080ARDB/LS2088ARDB RevF board has smart voltage translator which needs to be programmed to enable high speed SD interface by setting GPIO4_10 output to zero. Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Santan Kumar <santan.kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-24armv8: ls2080ardb: Add phy number for serdes1 protocol 0x4bSantan Kumar
2017-04-12arm: freescale: Rename initdram() to fsl_initdram()Simon Glass
This function name shadows a global name but is in fact different. This is very confusing. Rename it to help with the following refactoring. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-03-28board: freescale: ls2080a/ls2088a: Enable PPASantan Kumar
Enable PPA on LS2080A, LS2088A boards: -LS2080ARDB, LS2080AQDS -LS2088ARDB, LS2088AQDS Signed-off-by: Santan Kumar <santan.kumar@nxp.com> Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-03-28armv8: LS2080A: Move sec_init to board_initUdit Agarwal
Moves sec_init to board_init rather than in misc_init function beacuse PPA will be initialised in board_init function and for PPA validation sec_init has to be done prior to PPA init. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-03-14armv8: layerscape: Update early MMU for DDR after initializationYork Sun
In early MMU table, DDR has to be mapped as device memory to avoid speculative access. After DDR is initialized, it needs to be updated to normal memory to allow code execution. To simplify the code, dram_init() is moved into a common file as a weak function. Signed-off-by: York Sun <york.sun@nxp.com>
2017-03-14armv8: layerscape: Rewrite memory reservationYork Sun
For ARMv8 Layerscape SoCs, secure memory and MC memorey are reserved at the end of DDR. DDR is spit into two or three banks. This patch reverts commit aabd7ddb and simplifies the calculation of reserved memory, and moves the code into common SoC file. Secure memory is carved out first. DDR bank size is reduced. Reserved memory is then allocated on the top of available memory. U-Boot still has access to reserved memory as data transferring is needed. Device tree is fixed with reduced memory size to hide the reserved memory from OS. The same region is reserved for efi_loader. Signed-off-by: York Sun <york.sun@nxp.com>
2017-01-24NXP: Introduce board/freescale/common/Kconfig and migrate CHAIN_OF_TRUSTTom Rini
Introduce board/freescale/common/Kconfig so that we have a single place for CONFIG options that are shared between ARM and PowerPC NXP platforms. Cc: York Sun <york.sun@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-12-15fsl/board/ddr: optimize board-specific cpo for erratum A-009942Shengzhou Liu
Optimize board-specific cpo for erratum A-009942 on b4860qds, ls1043aqds, ls1043ardb, ls1046aqds, ls1046ardb, ls2080ardb, t102xqds, t102xrdb, t1040qds, t104xrdb, t208xqds, t208xrdb, t4qds, t4rdb boards. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-22armv8: fsl-layerscape: Add NXP LS2088A SoC supportPriyanka Jain
The QorIQ LS2088A SoC is built on layerscape architecture. It is similar to LS2080A SoC with some differences like 1)Timer controller offset is different 2)It has A72 cores 3)It supports TZASC module Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-17ls2080ardb: Reserve DP-DDR RAMAlexander Graf
The DP-DDR shouldn't be exposed as conventional memory to an OS, so let's rather claim it's a reserved region in the EFI memory map Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-17ls2080: Exit dpaa only right before exiting U-BootAlexander Graf
On ls2080 we have a separate network fabric component which we need to shut down before we enter Linux (or any other OS). Along with that also comes configuration of the fabric using a description file. Today we always stop and configure the fabric in the boot script and (again) exit it on device tree generation. This works ok for the normal booti case, but with bootefi the payload we're running may still want to access the network. So let's add a new fsl_mc command that defers configuration and stopping the hardware to when we actually exit U-Boot, so that we can still use the fabric from an EFI payload. For existing boot scripts, nothing should change with this patch. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: York Sun <york.sun@nxp.com> [agraf: Fix x86 build]
2016-09-27usb: fsl: Rename fdt_fixup_dr_usbSriram Dash
The function fdt_fixup_dr_usb is specific to fsl/nxp. So, make the function name explicit and rename fdt_fixup_dr_usb into fsl_fdt_fixup_dr_usb. Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2016-09-14armv8: ls2080a: Remove debug server supportYork Sun
Debug server feature has been dropped from roadmap. Signed-off-by: York Sun <york.sun@nxp.com>
2016-07-15armv8: Move secure_ram variable out of generic global dataYork Sun
Secure_ram variable was put in generic global data. But only ARMv8 uses this variable. Move it to ARM specific data structure. Signed-off-by: York Sun <york.sun@nxp.com>
2016-06-18Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h
2016-06-13usb: xhci: fsl: Add workaround for USB erratum A008751Sriram Dash
This patch is doing the following: 1. Implementing the errata for LS2080. 2. Adding fixup for fdt for LS2080. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2016-06-10board: ls2080a: Add "mcinitcmd" env for MC & DPL deploymentPratiyush Mohan Srivastava
Environment variable mcinitcmd is defined to initiate MC and DPL deployment from the location where it is stored (NOR, NAND, SD, SATA, USB) during booting. If this variable is not defined then macro MC_BOOT_ENV_VAR will be null and MC will not be booted and DPL will not be applied during U-boot booting. Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03armv8: fsl-layerscape: Organize SoC overview at common locationPrabhakar Kushwaha
SoC overviews are getting repeated across board folders. So, Organize SoC overview at common location i.e. fsl-layerscape/doc Also move README.lsch2 and README.lsch3 in same folder. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03board: ls2080ardb: qds: Fix compiling issue when FSL_MC_ENET not definedYork Sun
U-Boot should continue to work without management complex (MC). Fix compiling errors and warnings. Signed-off-by: York Sun <york.sun@nxp.com>
