path: root/board/freescale/ls2080ardb/MAINTAINERS
2019-01-17armv8: ls2088ardb: Update MAINTAINERSYork Sun
Signed-off-by: York Sun <york.sun@nxp.com> CC: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2019-01-17armv8: ls2088ardb: Add TFABOOT supportRajesh Bhagat
TFABOOT support includes: - ls2088ardb_tfa_defconfig to be loaded by trusted firmware - environment address and size changes for TFABOOT - define BOOTCOMMAND for TFABOOT - remove EL3 specific erratas for TFABOOT Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-05-10board/freescale: Remove invalid fsl email addressesFabio Estevam
These fsl email addresses are no longer valid and they do not have a correspondent nxp.com entry. Remove all invalid fsl email addresses and mark the boards as orphan. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-09-11armv8: LS2080ARDB: Add secure boot defconfig for QSPI boot.Udit Agarwal
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> [YS: dropped redundant commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23armv8: ls2080ardb: Add LS2081ARDB board supportPriyanka Jain
LS2081ARDB board is similar to LS2080ARDB board with few differences It hosts LS2081A SoC Default boot source is QSPI-boot It does not have IFC interface RTC and QSPI flash device are different It provides QIXIS access via I2C Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Santan Kumar <santan.kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23armv8: ls2080ardb: Add QSPI-boot supportPriyanka Jain
QSPI-boot is supported on LS2088ARDB RevF board with LS2088A SoC. LS2088ARDB RevF Board has limitation that QIXIS can not be accessed. CONFIG_FSL_QIXIS is not enabled. Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Suresh Gupta <suresh.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-22armv8: fsl-layerscape: Add NXP LS2088A SoC supportPriyanka Jain
The QorIQ LS2088A SoC is built on layerscape architecture. It is similar to LS2080A SoC with some differences like 1)Timer controller offset is different 2)It has A72 cores 3)It supports TZASC module Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-17armv8: ls2080a: Update MAINTAINERS filePrabhakar Kushwaha
Update MAINTAINERS file for ls2080aqds and ls2080ardb platforms. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-04-06armv8: LS2080A: Consolidate LS2080A and LS2085AYork Sun
LS2080A is the primary SoC, and LS2085A is a personality with AIOP and DPAA DDR. The RDB and QDS boards support both personality. By detecting the SVR at runtime, a single image per board can support both SoCs. It gives users flexibility to swtich SoC without the need to reprogram the board. Signed-off-by: York Sun <york.sun@nxp.com> CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2016-03-29armv8: ls2080rdb: ls2080qds: Add secure boot supportSaksham Jain
Sec_init has been called at the beginning to initialize SEC Block (CAAM) which is used by secure boot validation later for both ls2080a qds and rdb. 64-bit address in ESBC Header has been enabled. Secure boot defconfigs are created for boards (NOR boot). Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-11-30armv8: ls2085a: Add support of LS2085A SoCPrabhakar Kushwaha
Freescale's LS2085A is a another personality of LS2080A SoC with support of AIOP and DP-DDR. This Patch adds support of LS2085A Personality. Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Updated MAINTAINERS files Dropped #ifdef in cpu.h Add CONFIG_SYS_NS16550=y in defconfig] Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30armv8: LS2080A: Rename LS2085A to reflect LS2080APrabhakar Kushwaha
LS2080A is a prime personality of Freescale’s LS2085A. It is a non-AIOP personality without support of DP-DDR, L2 switch, 1588, PCIe endpoint etc. So renaming existing LS2085A code base to reflect LS2080A (Prime personality) Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Dropped #ifdef in cpu.c for cpu_type_list] Reviewed-by: York Sun <yorksun@freescale.com>
