path: root/board/freescale/ls1043ardb/MAINTAINERS
2018-05-01MAINTAINERS: Switch nxp.com domainFabio Estevam
freescale.com domain is no longer reachable, so switch the maintainers' emails to nxp.com domain instead. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-04-17arm: ls1043ardb: Add NAND secure boot targetRuchika Gupta
Add NAND secure boot target for ls1043ardb. - Change the u-boot size defined by a macro for copying the main U-Boot by SPL to also include the u-boot Secure Boot header size as header is appended to u-boot image. So header will also be copied from SD to DDR. - MACRO for CONFIG_BOOTSCRIPT_COPY_RAM is enabled to copy Bootscript from NAND to DDR. Offsets for Bootscript on NAND and DDR have been also defined. Signed-off-by: Vinitha Pillai <vinitha.pillai@nxp.com> Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-17arm: ls1043ardb: Add SD secure boot targetRuchika Gupta
- Add SD secure boot target for ls1043ardb. - Implement FSL_LSCH2 specific spl_board_init() to setup CAAM stream ID and corresponding stream ID in SMMU. - Change the u-boot size defined by a macro for copying the main U-Boot by SPL to also include the u-boot Secure Boot header size as header is appended to u-boot image. So header will also be copied from SD to DDR. - CONFIG_MAX_SPL_SIZE is limited to 90KB. SPL is copied to OCRAM (128K) where 32K are reserved for use by boot ROM and 6K for secure boto header. - Error messages during SPL boot are limited to error code numbers instead of strings to reduce the size of SPL image. Signed-off-by: Vinitha Pillai-B57223 <vinitha.pillai@nxp.com> Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-08-02board/freescale: Update MAINTAINERS filesYork Sun
Update maintainers for secure boot targets. Signed-off-by: York Sun <york.sun@nxp.com>
2015-12-15armv8/ls1043ardb: add SECURE BOOT target for NORAneesh Bansal
LS1043ARDB Secure Boot Target from NOR has been added. - Configs defined to enable esbc_validate. - ESBC Address in header is made 64 bit. - SMMU is re-configured in Bypass mode. Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-10ls1043ardb: Add missing config entries to MAINTAINERSFabio Estevam
ls1043ardb_nand_defconfig and ls1043ardb_sdcard_defconfig are missing in the MAINTAINERS file, so add them for completeness. Reported-by: Albert Aribaud <albert.u.boot@aribaud.net> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-10-29armv8/ls1043ardb: Add LS1043ARDB board supportMingkai Hu
LS1043ARDB Specification: ------------------------- Memory subsystem: * 2GByte DDR4 SDRAM (32bit bus) * 128 Mbyte NOR flash single-chip memory * 512 Mbyte NAND flash * 16 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card Ethernet: * XFI 10G port * QSGMII with 4x 1G ports * Two RGMII ports PCIe: * PCIe2 (Lanes C) to mini-PCIe slot * PCIe3 (Lanes D) to PCIe slot USB 3.0: two super speed USB 3.0 type A ports UART: supports two UARTs up to 115200 bps for console Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
