path: root/board/freescale/ls1043aqds/ddr.c
2018-12-06armv8: ls1043aqds: Add TFABOOT supportRajesh Bhagat
TFABOOT support includes: - ls1043aqds_tfa_defconfig to be loaded by trusted firmware - environment address and size changes for TFABOOT - define BOOTCOMMAND for TFABOOT Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-06-05common: freescale: Move arch-specific declarationsSimon Glass
The declarations should not be in common.h. Move them to the arch-specific headers. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup thinko defined(FSL_LSCH3) -> defined(CONFIG_FSL_LSCH3)] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-24armv8: layerscape: Fix DDR size calcuation for SPL buildYork Sun
Commit 088454cd dropped return value from initram(), setting gd->ram_size directly. Three boards were missed for SPL boot. Signed-off-by: York Sun <york.sun@nxp.com>
2017-04-12arm: freescale: Rename initdram() to fsl_initdram()Simon Glass
This function name shadows a global name but is in fact different. This is very confusing. Rename it to help with the following refactoring. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-03-14armv8: layerscape: Rewrite memory reservationYork Sun
For ARMv8 Layerscape SoCs, secure memory and MC memorey are reserved at the end of DDR. DDR is spit into two or three banks. This patch reverts commit aabd7ddb and simplifies the calculation of reserved memory, and moves the code into common SoC file. Secure memory is carved out first. DDR bank size is reduced. Reserved memory is then allocated on the top of available memory. U-Boot still has access to reserved memory as data transferring is needed. Device tree is fixed with reduced memory size to hide the reserved memory from OS. The same region is reserved for efi_loader. Signed-off-by: York Sun <york.sun@nxp.com>
2016-12-15fsl/board/ddr: optimize board-specific cpo for erratum A-009942Shengzhou Liu
Optimize board-specific cpo for erratum A-009942 on b4860qds, ls1043aqds, ls1043ardb, ls1046aqds, ls1046ardb, ls2080ardb, t102xqds, t102xrdb, t1040qds, t104xrdb, t208xqds, t208xrdb, t4qds, t4rdb boards. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-15armv8: Move secure_ram variable out of generic global dataYork Sun
Secure_ram variable was put in generic global data. But only ARMv8 uses this variable. Move it to ARM specific data structure. Signed-off-by: York Sun <york.sun@nxp.com>
2016-05-17armv8/ls1043: Add workaround for DDR erratum A-008850Shengzhou Liu
Barrier transactions from CCI400 need to be disabled till the DDR is configured, otherwise it may lead to system hang. The patch adds workaround to fix the erratum. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-25armv8/ls1043aqds: Add support for >2GB memoryShaohui Xie
This patch also exposes the complete DDR region(s) to Linux. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-12-15armv8: fsl-layerscape: Make DDR non secure in MMU tablesYork Sun
DDR has been set as secure in MMU tables. Non-secure master such as SDHC DMA cannot access data correctly. Mixing secure and non- secure MMU entries requirs the MMU tables themselves in secure memory. This patch moves MMU tables into a secure DDR area. Early MMU tables are changed to set DDR as non-secure. A new table is added into final MMU tables so secure memory can have 2MB granuality. gd->secure_ram tracks the location of this secure memory. For ARMv8 SoCs, the RAM base is not zero and RAM is divided into several banks. gd->secure_ram needs to be maintained before using. This maintenance is board-specific, depending on the SoC and memory bank of the secure memory falls into. Signed-off-by: York Sun <yorksun@freescale.com>
2015-11-30armv8/ls1043aqds: add LS1043AQDS board supportShaohui Xie
LS1043AQDS Specification: ------------------------- Memory subsystem: * 2GByte DDR4 DIMM * 128 Mbyte NOR flash single-chip memory * 512 Mbyte NAND flash * 16 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card Ethernet: * Two RGMII ports * XFI 10G port * SGMII * QSGMII with 4x 1G ports PCIe: supports Gen 1 and Gen 2 SATA 3.0: one SATA 3.0 port USB 3.0: two micro AB connector and one type A connector UART: supports two UARTs up to 115200 bps for console Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> [York Sun: Add CONFIG_SYS_NS16550=y in defconfig] Reviewed-by: York Sun <yorksun@freescale.com>
