path: root/board/freescale/ls1021atwr/ls1021atwr.c
2016-09-14armv7:ls1021a: Enable workaround for DDR erratum A-009942Shengzhou Liu
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14fsl-layerscape: Add workaround for PCIe erratum A010315Hou Zhiqiang
As the access to serders protocol unselected PCIe controller will hang. So disable the R/W permission to unselected PCIe controller including its CCSR, IO space and memory space according to the serders protocol field of RCW. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14arm: fsl-layerscape: move forward the non-secure access permission setupHou Zhiqiang
Move forward the basic non-secure access enable operation, so the subsequent individual device access permission can override it. And collect the dispersed callers in board level, and then move them to SoC level. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-26arm: ls1021atwr: Add SD secure boot targetSumit Garg
Add SD secure boot target for ls1021atwr. Implement board specific spl_board_init() to setup CAAM stream ID and corresponding stream ID in SMMU. Change the u-boot size defined by a macro for copying the main U-Boot by SPL to also include the u-boot Secure Boot header size as header is appended to u-boot image. So header will also be copied from SD to DDR. Reviewed-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24armv7: ls102xa: Move smmu and stream id initialization into the common soc codeAlison Wang
The initialization for smmu and stream id is moved into the common soc code. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24qe: move drivers/qe/qe.h to include/fsl_qe.hQianyu Gong
As the QE firmware struct is shared with Fman, move the header file out of drivers/qe/. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-28Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2016-01-28arm: ls1021atwr: Do not wrap pci_eth_init() with CONFIG_TSEC_ENETBin Meng
The call to pci_eth_init() should not be wrapped with CONFIG_TSEC_ENET. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27secure_boot: enable chain of trust for ARM platformsAneesh Bansal
Chain of Trust is enabled for ARM platforms (LS1021 and LS1043). In board_late_init(), fsl_setenv_chain_of_trust() is called which will perform the following: - If boot mode is non-secure, return (No Change) - If boot mode is secure, set the following environmet variables: bootdelay = 0 (To disable Boot Prompt) bootcmd = CONFIG_CHAIN_BOOT_CMD (Validate and execute Boot script) Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-12-13arm: ls1021a: merge SoC specific code in a separate fileYao Yuan
Create a soc.c file to put the code for soc special settings. Signed-off-by: Yuan Yao <yao.yuan@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-30arm: ls1021atwr: optimize the deep sleep latencytang yuantian
It will take more than 1s when wake up from deep sleep. Most of the time is spent on outputing information. This patch reduced the deep sleep latency by: 1. avoid outputing system informaton 2. remove flush cache after DDR restore 3. skip reloading second stage uboot binary when SD boot Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29arm: ls1021a: Add sata support on qds and twr boardtang yuantian
Freescale ARM-based Layerscape LS102xA contain a SATA controller which comply with the serial ATA 3.0 specification and the AHCI 1.3 specification. This patch adds SATA feature on ls1021aqds and ls1021atwr boards. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv7/ls1021a: move ns_access to common fileMingkai Hu
Config Security Level Register is different between different SoCs, so put the CSL register definition into the arch specific directory. Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-26arm: ls1021a: Add QSPI or IFC support in SD bootAlison Wang
As QSPI and IFC are pin-multiplexed on LS1021A, only IFC is supported in SD boot now. For the customer's demand, QSPI needs to be supported in SD boot too. This patch adds QSPI or IFC support in SD boot according to the corresponding defconfig. For detail, ls1021atwr_sdcard_ifc_defconfig is used to support IFC in SD boot and ls1021atwr_sdcard_qspi_defconfig is used to support QSPI in SD boot. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-09-01arm/ls102xa:add hwconfig setting to support disable unused devicesZhuoyu Zhang
DEVDISRn registers provides a mechanism for gating clocks of IP blocks that are not used. Here we implement hwconfig option to allow users to disable unused peripherals on the board. For ex. If eSDHC/qDMA/eDMA are unused and with disabled status in dts, User can enable CONFIG_FSL_DEVICE_DISABLE and set "devdis:esdhc,qdma,edma" in hwconfig, thus ESDHC controller & eDMA/qDMA will be clock gated to save more power. Signed-off-by: Zhuoyu Zhang <Zhuoyu.Zhang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-09-01ls102xa: etsec: Use proper settings for BE BDsClaudiu Manoil
Replace the DMACTRL[LE] hack with recommended settings for ETSECDMAMCR to get the same end effect - obtaining big-endian buffer descriptors and frame data for eTSEC. The reset / default value for ETSECDMAMCR is preserved, excepting the BD and FR bits which are cleared to enable the BE mode in accordance with the H/W specifications. Fixes: 52d00a8 "ls102xa: etsec: Add etsec support for LS102xA" Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com> Acked-by: Alison Wang <alison.wang@freescale.com> Tested-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-08-03armv7/ls1021a: allow OCRAM access permission as R/W in SPLAlison Wang
On LS1021A Rev2.0, OCRAM's security level needs to be changed to non-secure access for SD boot. This patch will allow OCRAM access permission as R/W in SPL. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-08-03armv7/ls1021atwr: program the regulator for deep sleepchenhui zhao
Program the external regulator to switch off voltage in deep sleep. Signed-off-by: Chenhui Zhao <chenhui.zhao@freescale.com> Acked-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-08-03armv7/ls1021atwr: added deep sleep support in ubootTang Yuantian
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Acked-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-20arm/ls102xa: Add little-endian mode support for audio IPsAlison Wang
As SCFG_ENDIANCR register is added to choose little-endian or big-endian for audio IPs on Rev2.0 silion, little-endian mode is selected. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-05-20arm/ls1021a: Remove ccsr_ddr from immap_ls102xa.hYork Sun
ccsr_ddr structure is already defined in fsl_immap.h. Remove this duplicated define. Move fixed timing into ls1021atwr.h. Signed-off-by: York Sun <yorksun@freescale.com> CC: Alison Wang <alison.wang@freescale.com> Acked-by: Alison Wang <alison.wang@freescale.com>
2015-04-21pci/layerscape: remove unnecessary pcie_layerscape.hMinghuan Lian
The patch uses the common function name ft_pci_setup to replace ft_pcie_setup, then removes unnecessary pcie_layerscape.h because all the functions have been declared in common.h. Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-21ls1021atwr: add hwconfig setting to do pin muxYao Yuan
Freescale LS1021ATWR share some pins. Hwconfig option is used to allows users to choose the pin functions. Signed-off-by: Yuan Yao <yao.yuan@freescale.com> [York Sun: revised commit message] Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-21arm/ls102xa:Add support of conditional workaround implementation as per SoC verAlison Wang
For LS102xA, some workarounds are only used in VER1.0, so silicon version detection are added for QDS and TWR boards. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-24arm: ls1021x: Add support for initializing CAAM's stream idAlison Wang
There 4 JRs, 4 RTICs and 8 DECOs, and set them the same stream id for using the same SMMU3 on LS1021A. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-23arm: ls102xa: Update snoop settings for CCI-400Alison Wang
CAAM is connected to CCI-400 S0 slave interface. Disable snooping for S0 will cause CAAM self test failure. This patch is to enable snooping for S0 slave interface. These CCI-400 operations are moved to board_early_init_f() to be initialized earlier. For S4 slave interface, issuing of snoop requests and DVM message requests are enabled. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-20imx: ls102xa: Remove reference to gdataSimon Glass
The global_data pointer (gd) has already been set before board_init_f() is called. We should not assign it again. We should also not use gdata since it is going away. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-11ARM: ls102xa: Setting device's stream id for SMMUs.Xiubo Li
LS1 has 4 SMMUs for address translation of the masters. All the SMMUs' stream IDs are 8-bit. The address translation depends on the stream ID of the incoming transaction. Each master has unique stream ID assigned to it and is configurable through SCFG registers. The stream ID for the masters is identical and share the same register field of STREAM ID registers. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11ARM: ls102xa: allow all the peripheral access permission as R/W.Xiubo Li
The Central Security Unit (CSU) allows secure world software to change the default access control policies of peripherals/bus slaves, determining which bus masters may access them. This allows peripherals to be separated into distinct security domains. Combined with SMMU configuration of the system masters privileges, these features provide protection against indirect unauthorized access to data. For now we configure all the peripheral access permissions as R/W. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls102xa: Add QSPI boot support for LS1021AQDS/TWR boardAlison Wang
This patch adds QSPI boot support for LS1021AQDS/TWR board. The QSPI boot image need to be programmed into the QSPI flash first. Then the booting will start from QSPI memory space. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls102xa: Add SD boot support for LS1021ATWR boardAlison Wang
This patch adds SD boot support for LS1021ATWR board. SPL framework is used. PBL initialize the internal RAM and copy SPL to it, then SPL initialize DDR using SPD and copy u-boot from SD card to DDR, finally SPL transfer control to u-boot. Signed-off-by: Chen Lu <chen.lu@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com> Signed-off-by: Jason Jin <jason.jin@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls102xa: Update PCIe dts node statusMinghuan Lian
The patch changes PCIe dts node status to 'disabled' if the corresponding controller is disabled according to serdes protocol. Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-26Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2014-11-24arm: ls102xa: Remove bit reversing for SCFG registersAlison Wang
SCFG_SCFGREVCR is SCFG bit reverse register. This register must be written with 0xFFFFFFFF before writing to any other SCFG register. Then other SCFG register could be written in big-endian mode. Address: 157_0000h base + 200h offset = 157_0200h Bit 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15|16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 W/R SCFGREV Reset 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0-31 SCFGREV SCFG Bit Reverse Control Filed 32'h 0000_0000 - No bit reverse is applied 32'h FFFF_FFFF - Bit reverse is applied; so 31:0 will be stored/read as 0:31 This patch removes the bit reversing for SCFG registers in u-boot. It will be implemented through PBI commands in RCW .pbi write 0x570200, 0xffffffff .end So other SCFG register could be written in big-endian mode in u-boot or kernel directly. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-24arm: ls102xa: Add snoop disable for slave port 0, 1 and 2Jason Jin
Disable the snoop for slave interface 0, 1 and 2 to avoid the interleaving on the CCI400 BUS. Signed-off-by: Jason Jin <Jason.Jin@freescale.com> Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-11-19qe: add qe support for ls1021a-twr boardZhao Qiang
Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-16ls102x: configs - Add hash command in freescale LS1 platformsRuchika Gupta
Hardware accelerated support for SHA-1 and SHA-256 has been added. Hash command enabled along with hardware accelerated support for SHA-1 and SHA-256 for platforms which have CAAM block. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-09-08ls102xa: dcu: Add platform support for DCU on LS1021ATWR boardWang Huan
This patch adds the TWR_LCD_RGB card/HDMI options and the common configuration for DCU on LS1021ATWR board. Signed-off-by: Alison Wang <alison.wang@freescale.com>
2014-09-08arm: ls102xa: Add basic support for LS1021ATWR boardWang Huan
LS102xA is an ARMv7 implementation. This patch is to add basic support for LS1021ATWR board. One DDR controller DUART1 is used as the console For the detail board information, please refer to README. Signed-off-by: Chen Lu <chen.lu@freescale.com> Signed-off-by: Yuan Yao <yao.yuan@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com>
