path: root/board/freescale/ls1012ardb
2018-12-10Merge tag 'fsl-qoriq-for-v2019.01-rc2' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
Add TFA boot flow for some Layerscape platforms Add support for lx2160a SoC [trini: Add a bunch of missing MAINTAINERS entries] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-12-06armv8: ls1012ardb: Add TFABOOT supportRajesh Bhagat
TFABOOT support includes: - ls1012ardb_tfa_defconfig to be loaded by trusted firmware - environment address and size changes for TFABOOT - define BOOTCOMMAND for TFABOOT - enable PFE validation for secure boot Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-08-07board: freescale: ls1012ardb: Add command to switch QSPI bankJagdish Gediya
Add command "boot_bank X" to switch the boot bank to either 1 or 2. Signed-off-by: Jagdish Gediya <jagdish.gediya@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-06-08board: Kconfig: Re-Arrangement of PPA firmware and header addressesBhaskar Upadhaya
PPA firmware and header address may vary depending upon different boards, configure ppa firmware and header address in board specific Kconfig. Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Signed-off-by: Jagdish Gediya <jagdish.gediya@nxp.com> Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-03-22board: freescale: ls1012a2g5rdb: enable network support on ls1012a2g5rdbCalvin Johnson
This patch enables ethernet support for ls1012a2g5rdb. Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com> Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-03-22board: freescale: ls1012ardb: enable network support on ls1012ardbCalvin Johnson
This patch enables ethernet support for ls1012ardb. Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com> Signed-off-by: Anjaneyulu Jagarlmudi <anji.jagarlmudi@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-01-15board: ls1012a: LS1012A-2G5RDB board supportBhaskar Upadhaya
LS1012A-2G5RDB belongs to LS1012A family with features 2 2.5G SGMII PFE MAC, SATA, USB 2.0/3.0, WiFi DDR, eMMC, QuadSPI, UART. Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-14armv8: ls1012ardb: support hwconfig for eSDHC1 enablingYangbo Lu
I2C reading for DIP switch setting is not reliable for LS1012ARDB RevD and later versions. This patch is to add hwconfig support to enable/disable eSDHC1 manually for these boards. Also drop 'status' fix-up for eSDHC0 and leave it as it is. It shouldn't always be fixed up with 'okay'. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-14armv8: ls1012ardb: add more board version informationYangbo Lu
Add LS1012ARDB RevC/RevC1/RevC2/RevD/RevE information and detect it when u-boot starts up. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-14armv8: ls1012ardb: clean up definitions for I2C IO expandersYangbo Lu
This patch is to clean up definitions for I2C IO expanders. The value 0x10 of __SW_BOOT_EMU is wrong. It should be 0x2. Fixed it in this patch. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-11fsl-layerscape: Consolidate registers space defination for CCI-400 busAshish Kumar
CoreLink Cache Coherent Interconnect (CCI) provides full cache coherency between two clusters of multi-core CPUs and I/O coherency for devices and I/O masters. This patch add new config option SYS_FSL_HAS_CCI400 and moves existing register space definaton of CCI-400 bus to fsl_immap to be shared. CONFIG_SYS_CCI400_ADDR is replaced with SYS_CCI400_OFFSET in Kconfig. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> [YS: revised commit message, squashed patches for armv8 and armv7] Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-17armv8: LS1012ARDB: Add QSPI Secure Boot targetVinitha Pillai-B57223
Add QSPI Secure Boot target to enable chain of trust Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Signed-off-by: Vinitha Pillai <vinitha.pillai@nxp.com> Reviewed-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-03-14armv8: layerscape: Update early MMU for DDR after initializationYork Sun
In early MMU table, DDR has to be mapped as device memory to avoid speculative access. After DDR is initialized, it needs to be updated to normal memory to allow code execution. To simplify the code, dram_init() is moved into a common file as a weak function. Signed-off-by: York Sun <york.sun@nxp.com>
2017-03-14armv8: layerscape: Rewrite memory reservationYork Sun
For ARMv8 Layerscape SoCs, secure memory and MC memorey are reserved at the end of DDR. DDR is spit into two or three banks. This patch reverts commit aabd7ddb and simplifies the calculation of reserved memory, and moves the code into common SoC file. Secure memory is carved out first. DDR bank size is reduced. Reserved memory is then allocated on the top of available memory. U-Boot still has access to reserved memory as data transferring is needed. Device tree is fixed with reduced memory size to hide the reserved memory from OS. The same region is reserved for efi_loader. Signed-off-by: York Sun <york.sun@nxp.com>
2017-02-03armv8: ls1012a: Add support of PPAPrabhakar Kushwaha
The PPA implements PSCI which requires for power managment. Added support of PPA for LS1012AQDS, LS1012ARDB and LS1012AFRDM. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-02-03board: freescale: ls1012a: Enable secure DDR on LS1012A platformsPrabhakar Kushwaha
PPA binary needs to be relocated on secure DDR, hence marking out a portion of DDR as secure if CONFIG_SYS_MEM_RESERVE_SECURE flag is set Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-24NXP: Introduce board/freescale/common/Kconfig and migrate CHAIN_OF_TRUSTTom Rini
Introduce board/freescale/common/Kconfig so that we have a single place for CONFIG options that are shared between ARM and PowerPC NXP platforms. Cc: York Sun <york.sun@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: ls1012a: define esdhc_status_fixup for RDB boardYangbo Lu
On LS1012ARDB board, three dual 1:4 mux/demux devices drive the SDHC2 signals to eMMC, SDIO wifi, SPI and Ardiuno shield. Only when we select eMMC and SDIO wifi, the SDHC2 could be used. Otherwise, the command inhibit bits of eSDHC2_PRSSTAT register will never release. This would cause below continious error messages in linux since it uses polling mode to detect card. "mmc1: Controller never released inhibit bit(s)." "mmc1: Controller never released inhibit bit(s)." "mmc1: Controller never released inhibit bit(s)." This patch is to define esdhc_status_fixup function for RDB to disable SDHC2 status if no SDIO wifi or eMMC is selected. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-26driver: ddr: fsl_mmdc: Pass board parameters through data structureYork Sun
Instead of using multiple macros, a data structure is used to pass board-specific parameters to MMDC DDR driver. Signed-off-by: York Sun <york.sun@nxp.com> CC: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-14driver/ddr/fsl: Add general MMDC driver and reuse common MMDC driver for ls1012aShengzhou Liu
This general MMDC driver adds basic support for Freescale MMDC (Multi Mode DDR Controller). Currently MMDC is integrated on ARMv8 LS1012A SoC for DDR3L, there will be a update to this driver to support more flexible configuration if new features (DDR4, multiple controllers/chip selections, etc) are implimented in future. Meantime, reuse common MMDC driver for LS1012ARDB/LS1012AQDS/ LS1012AFRDM. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14fsl-layerscape: Add workaround for PCIe erratum A010315Hou Zhiqiang
As the access to serders protocol unselected PCIe controller will hang. So disable the R/W permission to unselected PCIe controller including its CCSR, IO space and memory space according to the serders protocol field of RCW. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14arm: fsl-layerscape: move forward the non-secure access permission setupHou Zhiqiang
Move forward the basic non-secure access enable operation, so the subsequent individual device access permission can override it. And collect the dispersed callers in board level, and then move them to SoC level. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03armv8: ls1012a: Add support of ls1012ardb boardPrabhakar Kushwaha
QorIQ LS1012A Reference Design System (LS1012ARDB) is a high-performance development platform, with a complete debugging environment. The LS1012ARDB board supports the QorIQ LS1012A processor and is optimized to support the high-bandwidth DDR3L memory and a full complement of high-speed SerDes ports. Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com> Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
