path: root/board/freescale/imx8mp_evk/spl.c
2020-06-08imx8mp_evk: spl: no need the code since spl framework could do thatPeng Fan
We no need invoke the code, since spl framework could help us do that. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Fabio Estevam <festevam@gmail.com>
2020-06-08imx8mp_evk: spl: use spl_early_initPeng Fan
Use spl_early_init to replace spl_init, spl_init will be invoked in board_init_r, we only need use spl_early_init to setup malloc and scan early dt. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Fabio Estevam <festevam@gmail.com>
2020-06-08imx8mp_evk: spl: drop timer_initPeng Fan
timer_init has been invoked in arch_cpu_init, no need to invoke it again in board code. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Fabio Estevam <festevam@gmail.com>
2020-06-08imx8mp_evk: spl: drop useless codePeng Fan
Drop useless getting ccm device, there is no need to explicted do this in board code, and we not enable SPL CLK currently. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Fabio Estevam <festevam@gmail.com>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop init.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop image.h from common headerSimon Glass
2020-05-01imx8mp_evk: Remove unrelated commentFabio Estevam
The comment does not relate to the setup_i2c() function, so just remove it. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2020-05-01imx: imx8m*: Remove do_reset from board filesClaudius Heine
Use the `do_reset` implementation of `arch/arm/lib/reset.c` in SPL instead. It is very close to what is done here, anyway, and plays more nicely with the rest of U-Boot than adding a custom `do_reset` implementation into board files. `do_reset` from `arch/arm/lib/reset.c` calls `reset_cpu` with 0 as the addr parameter while the boards are passing WDOG1_BASE_ADDR. This is ok because the `reset_cpu` implementation uses WDOG1_BASE_ADDR by default if 0 is passed in. Co-Authored-by: Harald Seiler <hws@denx.de> Signed-off-by: Claudius Heine <ch@denx.de> Signed-off-by: Harald Seiler <hws@denx.de> Reviewed-by: Marek Vasut <marex@denx.de>
2020-01-17common: Move hang() to the same header as panic()Simon Glass
At present panic() is in the vsprintf.h header file. That does not seem like an obvious choice for hang(), even though it relates to panic(). So let's put hang() in its own header. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Migrate a few more files] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-17common: Move reset_cpu() to the CPU headerSimon Glass
Move this function out of common.h and into a relevant header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-08imx: add i.MX8MP EVK boardPeng Fan
Add basic i.MX8MP EVK board support U-Boot SPL 2020.01-rc4-00388-gb1bf40c0ae-dirty (Dec 30 2019 - 17:55:33 +0800) power_pca9450b_init DDRINFO: start DRAM init DDRINFO:ddrphy calibration done DDRINFO: ddrmix config done Normal Boot Failed to find clock node. Check device tree WDT: Not found! Trying to boot from BOOTROM image offset 0x8000, pagesize 0x200, ivt offset 0x0 U-Boot 2020.01-rc4-00388-gb1bf40c0ae-dirty (Dec 30 2019 - 17:55:33 +0800) CPU: Freescale i.MX8MP rev1.0 at 1000 MHz Reset cause: POR Model: NXP i.MX8MPlus EVK board DRAM: 6 GiB MMC: FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... OK In: serial Out: serial Err: serial Net: No ethernet found. Hit any key to stop autoboot: 0 u-boot=> mmc list FSL_SDHC: 1 (SD) FSL_SDHC: 2 Signed-off-by: Peng Fan <peng.fan@nxp.com>
