path: root/board/freescale/corenet_ds/corenet_ds.c
2013-02-04ppc: Move lbc_clk and cpu to arch_global_dataSimon Glass
Move these fields into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Update for bsc9132qds.c, b4860qds.c] Signed-off-by: Tom Rini <trini@ti.com>
2012-11-27powerpc/85xx: add support for the Freescale P5040DS Superhydra reference boardTimur Tabi
The P5040DS reference board (a.k.a "Superhydra") is an enhanced version of P3041DS/P5020DS ("Hydra") reference board. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-04-24powerpc/85xx: don't display address map size (32-bit vs. 36-bit) during bootTimur Tabi
Most 85xx boards can be built as a 32-bit or a 36-bit. Current code sometimes displays which of these is actually built, but it's inconsistent. This is especially problematic since the "default" build for a given 85xx board can be either one, so if you don't see a message, you can't always know which size is being used. Not only that, but each board includes code that displays the message, so there is duplication. The 'bdinfo' command has been updated to display this information, so we don't need to display it at boot time. The board-specific code is deleted. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-09-29powerpc/85xx: Cleanup extern in corenet_ds board codeKumar Gala
Move extern of pci_of_setup() into corenet_ds.h Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29powerpc/85xx: Add FMan ethernet support to P4080DSAndy Fleming
Add support for RGMII, SGMII, and XAUI (10Gb) Ethernet on P4080DS. The board supports add-on cards for SGMII and XAUI functionality. Which slots on the board these cards are in is a function of the SERDES option selected and muxes on the board. Additionally because of the high-configurablity which MDIO bus one is connected to is "selected" via an FPGA register. We create dummy MDIO bus for the phy layer and hide the mux manipulation in this dummy layer. Add fman fdt helper function in board common code it'll be used by several freescale boards that do various muxing of the MDIO signals based on which controller/interface one is trying to talk to. Removed CONFIG_SYS_FMAN_FW as its not used anywhere. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-29powerpc/85xx: enable USB2 gadget mode for corenet ds boardShaohui Xie
to make USB2 worked in gadget mode, we need to set it's 'dr_mode' to 'peripheral' in hwconfig, but driver starts scan from 'usb1', it'll break out if it cannot find 'usb1', so drop the 'else' clause to make driver scan all the 'usbx'. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Fix compile errors if CONFIG_SYS_DPAA_QBMAN isn't setKumar Gala
Add ifdef protection for qp_info and liodn associated with Q/BMan. Also rearrange setting of _tbl_sz variables to utilize existing ifdef protection for things like FMAN. Also add protection around setup_portals() call in corenet_ds board code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-27powerpc: Add P3041DS/P5020DS board support (uses corenet_ds code)Kumar Gala
The P3041DS & P5020DS boards are almost identical (except for the processor in them). Additionally they are based on the P4080DS board design so we use the some board code for all 3 boards. Some ngPIXIS (FPGA) registers where reserved on P4080DS and now have meaning on P3041DS/P5020DS. We utilize some of these for SERDES clock configuration. Additionally, the P3041DS/P5020DS support NAND. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Shaohui Xie <b21989@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc: Move cpu specific lmb reserve to arch_lmb_reserveKumar Gala
We've been utilizing board_lmb_reserve to reserve the boot page for MP systems. We can just move this into arch_lmb_reserve for 85xx & 86xx systems rather than duplicating in each board port. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/8xxx: Refactor SRIO initialization into common codeKumar Gala
Moved the SRIO init out of corenet_ds and into common code for 8xxx/QorIQ processors that have SRIO. We mimic what we do with PCIe controllers for SRIO. We utilize the fact that SRIO is over serdes to determine if its configured or not and thus can setup the LAWs needed for it dynamically. We additionally update the device tree (to remove the SRIO nodes) if the board doesn't have SRIO enabled. Introduced the following standard defines for board config.h: CONFIG_SYS_SRIO - Chip has SRIO or not CONFIG_SRIO1 - Board has SRIO 1 port available CONFIG_SRIO2 - Board has SRIO 2 port available (where 'n' is the port #) CONFIG_SYS_SRIOn_MEM_VIRT - virtual address in u-boot CONFIG_SYS_SRIOn_MEM_PHYS - physical address (for law setup) CONFIG_SYS_SRIOn_MEM_SIZE - size of window (for law setup) [ These mimic what we have for PCI and PCIe controllers ] Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2010-11-12powerpc/corenet_ds: display the RCW at bootTimur Tabi
Display the 64-byte Reset Configuration Word (RCW) during boot, so that there's no confusion as to what RCW U-boot is using. Reset Configuration Word (RCW): 00000000: 4a500000 00000000 18181818 00008888 00000010: 28402400 00002000 fe800000 01200000 00000020: 00000000 00000000 00000000 000b0000 00000030: 00000000 00000000 00000000 00000000 Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-20Adding fixed sdram setting for cornet_ds boardYork Sun
800, 900, 1000, 1200MT/s data rate parameters are added for fixed sdram setting. SPD based parameters and fixed parameters can be toggled by hwconfig. To use fixed parameters, hwconfig=fsl_ddr:sdram=fixed To use SPD parameters, hwconfig=fsl_ddr:ctlr_intlv=cacheline,bank_intlv=cs0_cs1 Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-08-19powerpc/85xx: Fix SRIO LAW setup on corenet_ds boardsLian Minghuan
In function board_early_init_r(), serdes will not be initialize yet. Thus sRIO was always considered disabled. Move the check for sRIO into misc_init_r() which is called after fsl_serdes_init(). Also, fixed warning associated with gur variable possibly not being used. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Lian Minghuan <B31939@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-08-01powerpc/p4080: Add support for the P4080DS boardKumar Gala
Add support for the P4080DS board, with the following features: * 36-bit only * Boots from NOR flash * FMAN drivers NOT supported * SPD DDR initialization Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Ashish Kalra <Ashish.Kalra@freescale.com> Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Lan Chunhe-B25806 <b25806@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
