Some boards use System EEPROM with 128-bytes instead of 256-bytes.
Since we regard 256-bytes EEPROM as standard EEPROM with default
value for MAX_NUM_PORTS. For those non-256-bytes EEPROM, we can
redefine MAX_NUM_PORTS in board-specific file to override the
default MAX_NUM_PORTS.
This patch doesn't impact on previous existing boards.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
T1040QDS is a high-performance computing evaluation, development and
test platform supporting the T1040 QorIQ Power Architecture™ processor.
T1040QDS board Overview
- Four e5500 cores, each with a private 256 KB L2 cache
- 256 KB shared L3 CoreNet platform cache (CPC)
- Interconnect CoreNet platform
- 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving
support
- Data Path Acceleration Architecture (DPAA) incorporating acceleration
for the following functions:
- Packet parsing, classification, and distribution
- Queue management for scheduling, packet sequencing, and congestion
management
- Cryptography Acceleration
- RegEx Pattern Matching Acceleration
- IEEE Std 1588 support
- Hardware buffer management for buffer allocation and deallocation
- Ethernet interfaces
- Integrated 8-port Gigabit Ethernet switch
- Four 1 Gbps Ethernet controllers
- SERDES Connections, 8 lanes supporting:
— PCI Express: supporting Gen 1 and Gen 2;
— SGMII
— QSGMII
— SATA 2.0
— Aurora debug with dedicated connectors
- DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and
Interleaving
-IFC/Local Bus
- NAND flash: 8-bit, async, up to 2GB.
- NOR: 8-bit or 16-bit, non-multiplexed, up to 512MB
- GASIC: Simple (minimal) target within Qixis FPGA
- PromJET rapid memory download support
- Ethernet
- Two on-board RGMII 10/100/1G ethernet ports.
- PHY #0 remains powered up during deep-sleep
- QIXIS System Logic FPGA
- Clocks
- System and DDR clock (SYSCLK, “DDRCLK”)
- SERDES clocks
- Power Supplies
- Video
- DIU supports video at up to 1280x1024x32bpp
- USB
- Supports two USB 2.0 ports with integrated PHYs
— Two type A ports with 5V@1.5A per port.
— Second port can be converted to OTG mini-AB
- SDHC
- SDHC port connects directly to an adapter card slot, featuring:
- Supporting SD slots for: SD, SDHC (1x, 4x, 8x) and/or MMC
— Supporting eMMC memory devices
- SPI
- On-board support of 3 different devices and sizes
- Other IO
- Two Serial ports
- ProfiBus port
- Four I2C ports
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
[York Sun: fix conflict in boards.cfg]
Acked-by-by: York Sun <yorksun@freescale.com>
Since the parameters need to be modified according to different Serdes
protocols at runtime, the const will block this. Also remove const from
arrays define used by vsc3316_config.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Acked-by: York Sun <yorksun@freescale.com>
Enable p1022ds to start from eSDHC with SPL.
Signed-off-by: Ying Zhang <b40530@freescale.com>
Fix the license header introduced by the following patches
Add TWR-P10xx board support
Add T4240EMU target
IDT8T49N222A configuration code
Add C29x SoC support
Add support for C29XPCIE board
Signed-off-by: York Sun <yorksun@freescale.com>
Add code for configuring IDT8T49N222A device for various output refclks
- The IDT8T49N222A is a low phase noise Frequency Translator / Synthesizer with
alarm and monitoring functions suitable for networking and
communications applications. It is able to generate wide range of output
frequencies.
- In B4860QDS, it has been used to generate different refclks to SerDes modules
- Programming of these devices are performed by I2C interface.
Signed-off-by: Shaveta Leekha <shaveta@freescale.com>
JEDEC spec requires the clocks to be stable before deasserting reset
signal for RDIMMs. Clocks start when any chip select is enabled and
clock control register is set. This patch also adds the interface to
toggle memory reset signal if needed by the boards.
[trini: Fixup common/cmd_io.c]
"pixis_reset help" command prints the message without a new line "\n",
which makes the prompt on the same line.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Linker script is not able find start.o binary. So add its absolute path in
u-boot-spl.lds. This change is similar to u-boot-nand.lds
common/Makefile: Avoid compiling unnecssary files
fsl_ifc_spl.c : It is is responsible for reading u-boot binary from
NAND flash and copying into DDR. It also transfer control from NAND SPL
to u-boot image present in DDR.
QIXIS includes frequency measurement functions for each major processor
clock input. After reset (and after clocks are stable), QIXIS measures
the clocks against a reference frequency and stores the results in
CLK_FREQ registers. A base register supplies a multiplier which allows
directly obtaining the measured value, without requiring knowledge of
the target system or QIXIS core frequency.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Add defines needed to access NAND, remove second flash bank that is
actually connected to NAND.
Add nand booting support for P1022DS with hardcoded DDR config using
SPL framework from 2011
Signed-off-by: Matthew McClintock <msm@freescale.com>
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Signed-off-by: Jiang Yutang <b14898@freescale.com>
property
For linux 3.x, the size of each item in interrupt-map property is 9 not 7.
Don't use the static value and calculate the size with following cells:
PCI #address-cells, PCI #interrupt-cells,
PIC address, PIC #address-cells, PIC #interrupt-cells.
Signed-off-by: Bin Jiang <bin.jiang@windriver.com>
This patch add support for storing the environment redundant on
mmc devices. Substantially it re-uses the logic from the NAND implementation,
that means using an incremental counter for marking newer data.
Signed-off-by: Michael Heimpold <mhei@heimpold.de>
QIXIS FPGA is accessable via both i2c and flash controller.
Only flash controller access is supported.
Add support of i2c based access. It is quite useful in the scenario
where either flash controller path is broken or not present.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Remove #ifdef so that "qixis dump" command is always available
Add "qixis_reset switch" command to dump switch settings
Qixis doesn't have 1:1 switch mapping. We need to reverse engineer from
registers to figure out switch settings. Not all bits are available.
QIXIS FPGA's QIXIS Tag Access register (QTAG) defines TAG, VER, DATE, IMAGE
fields. These fields have FPGA build version, image name and build date
information.
Add support to parse these fields to have complete FPGA image information.
The P5040DS reference board (a.k.a "Superhydra") is an enhanced version of
P3041DS/P5020DS ("Hydra") reference board.
fsl_corenet_serdes.c:485:6: warning: symbol '__soc_serdes_init' was not declared. Should it be static?
cpu_init.c:185:6: warning: symbol 'invalidate_cpc' was not declared. Should it be static?
bcsr.c:28:27: warning: non-ANSI function declaration of function 'enable_8568mds_duart'
bcsr.c:39:33: warning: non-ANSI function declaration of function 'enable_8568mds_flash_write'
bcsr.c:46:34: warning: non-ANSI function declaration of function 'disable_8568mds_flash_write'
bcsr.c:53:29: warning: non-ANSI function declaration of function 'enable_8568mds_qe_mdio'
bcsr.c:28:33: warning: non-ANSI function declaration of function 'enable_8569mds_flash_write'
bcsr.c:33:34: warning: non-ANSI function declaration of function 'disable_8569mds_flash_write'
bcsr.c:38:28: warning: non-ANSI function declaration of function 'enable_8569mds_qe_uec'
bcsr.c:63:47: warning: non-ANSI function declaration of function 'disable_8569mds_brd_eeprom_write_protect'
ngpixis.c:245:1: error: directive in argument list
ngpixis.c:247:1: error: directive in argument list
Add code for configuring VSC3316/3308 crosspoint switches
Add README to understand the APIs
- VSC 3316/3308 is a low-power, low-cost asynchronous crosspoint switch
capable of data rates upto 11.5Gbps. VSC3316 has 16 input and 16
output ports whereas VSC3308 has 8 input and 8 output ports.
Programming of these devices are performed by two-wire or four-wire
serial interface.
According to new QIXIS system definition, update QIXIS registers set
to add present2 register instead of obsolete ctl_sys2.
QIXIS FPGA layout defines the address of registers but The actual register bit
implementation is board-specific,
So avoid use of magic numbers as it may vary across different boards's QIXIS
FPGA implementation.
Also, Avoid board specific defines in common/qixis.h
The P3060 was cancelled before it went into production, so there's no point
in supporting it.
In order to figure out which SerDes lane a given Fman port is connected
to, we need a function that maps the fm_port namespace to the srds_prtcl
namespace.
When boot from PCIE, slave's core should be in holdoff after powered on for
some specific requirements. Master will release the slave's core at the
right time by PCIE interface.
Slave's ucode and ENV can be stored in master's memory space, then slave
can fetch them through PCIE interface. For the corenet platform, ucode is
for Fman.
NOTE: Because the slave can not erase, write master's NOR flash by
PCIE interface, so it can not modify the ENV parameters stored
in master's NOR flash using "saveenv" or other commands.
environment and requirement:
master:
1. NOR flash for its own u-boot image, ucode and ENV space.
2. Slave's u-boot image is in master NOR flash.
3. Put the slave's ucode and ENV into it's own memory space.
4. Normally boot from local NOR flash.
5. Configure PCIE system if needed.
slave:
1. Just has EEPROM for RCW. No flash for u-boot image, ucode and ENV.
2. Boot location should be set to one PCIE interface by RCW.
3. RCW should configure the SerDes, PCIE interfaces correctly.
4. Must set all the cores in holdoff by RCW.
5. Must be powered on before master's boot.
For the slave module, need to finish these processes:
1. Set the boot location to one PCIE interface by RCW.
2. Set a specific TLB entry for the boot process.
3. Set a LAW entry with the TargetID of one PCIE for the boot.
4. Set a specific TLB entry in order to fetch ucode and ENV from
master.
5. Set a LAW entry with the TargetID one of the PCIE ports for
ucode and ENV.
6. Slave's u-boot image should be generated specifically by
make xxxx_SRIO_PCIE_BOOT_config.
This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
In addition, the processes are very similar between boot from SRIO and
boot from PCIE. Some configurations like the address spaces can be set to
the same. So the module of boot from PCIE was added based on the existing
module of boot from SRIO, and the following changes were needed:
1. Updated the README.srio-boot-corenet to add descriptions about
boot from PCIE, and change the name to
README.srio-pcie-boot-corenet.
2. Changed the compile config "xxxx_SRIOBOOT_SLAVE" to
"xxxx_SRIO_PCIE_BOOT", and the image builded with
"xxxx_SRIO_PCIE_BOOT" can support both the boot from SRIO and
from PCIE.
3. Updated other macros and documents if needed to add information
about boot from PCIE.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
When compile the slave image for boot from SRIO, no longer need to
specify which SRIO port it will boot from. The code will get this
information from RCW and then finishes corresponding configurations.
This has the following advantages:
1. No longer need to rebuild an image when change the SRIO port for
boot from SRIO, just rewrite the new RCW with selected port,
then the code will get the port information by reading new RCW.
2. It will be easier to support other boot location options, for
example, boot from PCIE.
PHYs on SGMII riser card are used in SGMII mode with different external
IRQs from eTSEC. This means in SGMII mode phy-handle and phy-connection-type
under ethernet node should be updated. Otherwise the PHY interrupt can not
be handled therefor PHY link state change can not be auto detected.
For we have seperate SGMII PHY nodes, ethernet PHY reg fixup is not needed
but it's still be kept to guarantee the sgmii mode could work with old
device tree.
Signed-off-by: Li Yang <leoli@freescale.com>
Signed-off-by: Jia Hongtao <B38951@freescale.com>
fdt_set_phy_handle() makes several FDT calls that could fail, so it should
not be hiding these errors.
When boot from SRIO, slave's ucode can be stored in master's memory space,
then slave can fetch the ucode image through SRIO interface. For the
corenet platform, ucode is for Fman.
Master needs to:
1. Put the slave's ucode image into it's own memory space.
2. Set an inbound SRIO window covered slave's ucode stored in master's
memory space.
Slave needs to:
1. Set a specific TLB entry in order to fetch ucode from master.
2. Set a LAW entry with the TargetID SRIO1 or SRIO2 for ucode.
For the powerpc processors with SRIO interface, boot location can be configured
from SRIO1 or SRIO2 by RCW. The processor booting from SRIO can do without flash
for u-boot image. The image can be fetched from another processor's memory
space by SRIO link connected between them.
The processor boots from SRIO is slave, the processor boots from normal flash
memory space and can help slave to boot from its memory space is master.
They are different environments and requirements:
master:
2. Slave's u-boot image in master NOR flash.
3. Normally boot from local NOR flash.
4. Configure SRIO switch system if needed.
slave:
2. Boot location should be set to SRIO1 or SRIO2 by RCW.
3. RCW should configure the SerDes, SRIO interfaces correctly.
4. Slave must be powered on after master's boot.
5. Must define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE because of no ucode
locally.
1. Set the boot location to SRIO1 or SRIO2 by RCW.
3. Set a LAW entry with the TargetID SRIO1 or SRIO2 for the boot.
4. Slave's u-boot image should be generated specifically by
make xxxx_SRIOBOOT_SLAVE_config.
Since commit 97039ab98 (env_mmc: Allow board code to override the environment address)
mmc_get_env_addr is a weak-aliased function in common/env_mmc.c
The mmc_get_env_addr implementation that exists at
board/freescale/common/sdhc_boot.c is meant to be used only for PowerPC boards,
but currently it is being used for all platforms that have CONFIG_ENV_IS_IN_MMC defined.
Introduce CONFIG_FSL_FIXED_MMC_LOCATION so that the boards that need to use
the mmc_get_env_addr version from board/freescale/common/sdhc_boot.c could activate
this config option on their board file.
This fixes the retrieval of CONFIG_ENV_OFFSET on non-PowerPC boards.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
The P3060QDS is a Freescale reference board for the six-core P3060 SOC.
P3060QDS Board Overview:
Memory subsystem:
- 2G Bytes unbuffered DDR3 SDRAM SO-DIMM(64bit bus)
- 128M Bytes NOR flash single-chip memory
- 16M Bytes SPI flash
- 8K Bytes AT24C64 I2C EEPROM for RCW
Ethernet:
- Eight Ethernet controllers (4x1G + 4x1G/2.5G)
- Three VSC8641 PHYs on board (2xRGMII + 1xMII)
- Suport multiple Vitesse VSC8234 SGMII Cards in Slot1/2/3
PCIe: Two PCI Express 2.0 controllers/ports
USB: Two USB2.0, USB1(TYPE-A) and USB2(TYPE-AB) on board
I2C: Four I2C controllers
UART: Supports two dUARTs up to 115200 bps for console
RapidIO: Two RapidIO, sRIO1 and sRIO2
Fix:
pixis.c: In function 'strfractoint':
pixis.c:383:6: warning: variable 'intarr_len' set but not used [-Wunused-but-set-variable]
Fix:
cds_pci_ft.c: In function 'cds_pci_fixup':
cds_pci_ft.c:31:12: warning: variable 'tmp' set but not used [-Wunused-but-set-variable]
For ICS307-02, there is one general expression to generate SYSCLK:
CLK1Frequency = InputFrequency * 2 * (VDW + 8) / ((RDW + 2) * OD)
If we want the required frequency for SYSCLK, we must find one solution
to generate this frequency, this solution includes VDW, RDW and OD.
For OD, there are only eight option value: 10, 2, 8, 4, 5, 7, 3, 6.
For RDW, the range is 1 to 127.
For VDW, the range is 4 to 511.
First, we use one OD, RDW and required SYSCLK to calculate the VDW,
if VDW is in it's range, we will calculate the CLK1Frequency with
the OD, RDW and VDW calculated, and we will check this percent
(CLK1Frequency / required SYSCLK), and the precision is 1/1000.
if the percent is less than 1/1000, we think the CLK1Frequency is we want.
Otherwise, We will continue to calculate it with the next OD and RDW.
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
The CDS uses PCICLK as SYSCLK. The PCICLK should be 33333333Hz or 66666666Hz.
Signed-off-by: Ebony Zhu <ebony.zhu@freescale.com>
Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com>
The P2041RDB has almost identical setup for TLB, LAWS, and PCI with
other P-Series CoreNet platforms.
The only difference between P2041RDB & P3041DS/P4080DS/P5020DS is the
CPLD vs PIXIS FPGA which we can handle via some simple #ifdefs in the
TLB and LAW setup tables.
We currently support 4 SoC/Boards from the P-Series of QorIQ SoCs that
are based on the 'CoreNet' Architecture: P2041RDB, P3041DS, P4080DS, and
P5020DS. There is a significant amount of commonality shared between
these boards that we can refactor into common code:
* Initial LAW setup
* Initial TLB setup
* PCI setup
We start by moving the shared code between P3041DS, P4080DS, and P5020DS
into a common directory to be shared with other P-Series CoreNet boards.
Add support for RGMII, SGMII, and XAUI (10Gb) Ethernet on P4080DS.
The board supports add-on cards for SGMII and XAUI functionality. Which
slots on the board these cards are in is a function of the SERDES option
selected and muxes on the board.
Additionally because of the high-configurablity which MDIO bus one is
connected to is "selected" via an FPGA register. We create dummy MDIO
bus for the phy layer and hide the mux manipulation in this dummy layer.
Add fman fdt helper function in board common code it'll be used by several
freescale boards that do various muxing of the MDIO signals based on which
controller/interface one is trying to talk to.
Removed CONFIG_SYS_FMAN_FW as its not used anywhere.
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
Signed-off-by: Shaohui Xie <b21989@freescale.com>
Add the 'pixis_reset dump' command, which displays the contents of the PIXIS
registers. This command is only available if DEBUG is defined.
The P3041DS & P5020DS boards are almost identical (except for the
processor in them). Additionally they are based on the P4080DS board
design so we use the some board code for all 3 boards.
Some ngPIXIS (FPGA) registers where reserved on P4080DS and now have
meaning on P3041DS/P5020DS. We utilize some of these for SERDES clock
configuration.
Additionally, the P3041DS/P5020DS support NAND.
We implement our own mmc_get_env_addr since the environment variables are
written to just after the u-boot image on SDCard, so we must read the MBR
to get the start address and code length of the u-boot image, then
calculate the address of the env.
Signed-off-by: Zhao Chenhui <b35336@freescale.com>
The NXID EEPROM format comes in two versions, v0 and v1. The only
difference is in the number of MAC addresses that can be stored. NXID v0
supports eight addresses, and NXID v1 supports 23.
Rather than allow a board to choose which version to support, NXID v0 is
now considered deprecated. The EEPROM code is updated to support only
NXID v1, but it can still read EEPROMs formatted with v0. In these cases,
the EEPROM data is loaded and the CRC is verified, but the data is stored
into a v1 data structure. If the EEPROM data is written back, it is
written in v1 format. This allows existing v0-formatted EEPROMs to
continue providing MAC addresses, but any changes to the data will force
an upgrade to the v1 format, while retaining all data.
The ngPIXIS is an FPGA used on the reference boards of most Freescale PowerPC
SOCs. Although programming the ngPIXIS is mostly standard on all boards that
have it, the P1022DS is unique in that the ngPIXIS needs to be programmed in
"indirect" mode whenever the video display (DIU) is active.
To support indirect mode, and to make it easier to support other quirks on
future reference boards, the low-level ngPIXIS functions are all marked as
weak, so that board-specific code can override any of them. We take advantage
of this feature on the P1022DS, so that we can properly reset the board when
the DIU is active.
The "mac id" command is used to initialize the EEPROM data to a specific
format, but it was not updating the CRC. This didn't cause any real
problems, because writing the data to the EEPROM will always update the
CRC anyway, but it did result in a bogus CRC warning.
Since the driver is used not only on Freescale boards,
we move it to a common place for video drivers as
suggested by Wolfgang. The patch also cleans up the
top level Makefile.
