path: root/board/freescale/common
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop flash.h from common headerSimon Glass
Move this uncommon header out of the common header. Fix up some style problems in flash.h while we are here. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-04dm: ppc: T4240: add i2c DM supportBiwen Li
This supports i2c DM for SoC T4240 Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-05-04dm: ppc: MPC8548CDS: add i2c DM supportBiwen Li
This supports i2c DM for board MPC8548CDS Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-02-04dm: arm: ls1021a: add i2c DM supportBiwen Li
This supports i2c DM and enables CONFIG_DM_I2C for SoC LS1021A Signed-off-by: Biwen Li <biwen.li@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-02-04board: fsl: lx2160a: Add support to reset to eMMCMeenakshi Aggarwal
Add support of "qixis_reset emmc" command for lx2160a based platforms Signed-off-by: Meenakshi Aggarwal <meenakshi.aggarwal@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-27pfuze: Fix the pmic_get() parameter in the DM caseFabio Estevam
Currently the following hang is observed when booting a imx6sx-sdb board: U-Boot 2020.01-rc5-00004-g643366bcd5 (Dec 19 2019 - 14:56:23 -0300) CPU: Freescale i.MX6SX rev1.0 996 MHz (running at 792 MHz) CPU: Extended Commercial temperature grade (-20C to 105C) at 32C Reset cause: POR Model: Freescale i.MX6 SoloX SDB RevB Board Board: MX6SX SABRE SDB revA DRAM: 1 GiB initcall sequence bffd8514 failed at call 87804cc0 (err=-19) ### ERROR ### Please RESET the board ### When pmic_get() is used with DM the first parameter must be the complete node name plus the unit address. Fix the pmic_get() parameter to fix the boot regression. Tested on a imx6sx-sdb and imx6q-sabresd boards. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-12-02common: Move pci_init_board() out of common.hSimon Glass
This function can be dropped when all boards use driver model for PCI. For now, move it into init.h with a comment. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move enable/disable_interrupts out of common.hSimon Glass
Move these two functions into the irq_funcs.h header file. Also move interrupt_handler_t as this is used by the irq_install_handler() function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-11-25board: sdhc: Use block layer to read from mmcYinbo Zhu
Use block layer to read from mmc Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-11-08freescale/powerpc: Rename the config CONFIG_SECURE_BOOT nameUdit Agarwal
Rename the CONFIG_SECURE_BOOT name to CONFIG_NXP_ESBC to avoid conflicts with UEFI secure boot. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-11-08freescale/layerscape: Rename the config CONFIG_SECURE_BOOT nameUdit Agarwal
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict with UEFI secure boot. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-08-28powerpc: MPC85xxCDS: Disable legacy PCI fixup when DM_PCI is selectedHou Zhiqiang
Disable legacy PCI and PCIe fixup when CONFIG_DM_PCI is selected. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-28powerpc: p_corenet: Compile legacy PCIe routines conditionallyHou Zhiqiang
Compile the legacy PCIe initialization routines for P2041RDB, P3041, P4080, P5020 and P5040 DS boards only when DM_PCI is not enabled. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-22boards: lx2160a: Add support of I2C driver modelChuanhua Han
DM_I2C_COMPAT is a compatibility layer that allows using the non-DM I2C API when DM_I2C is used. When DM_I2C_COMPAT is not enabled for compilation, a compilation error will be generated. This patch solves the problem that the i2c-related api of the lx2160a platform does not support dm. Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-22common: qixis: make the qixis compatible with new socYuantian Tang
This driver needs modification to work with new soc, like ls1028, since bitmap of RCFG is changed to RESV[7:5] LIVE[4] WDEN[3] RESV[2:1] GO[0] 000 1 0 00 0 Also the RCW location is moved to only dutcfg0. RESV[7:4] RCWSRC[3:0] 1111 configurable Following commands are functional now qixis_reset qixis_reset sd qixis_reset qspi qixis_reset emmc Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Yuantian Tang <andy.tang@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-11env: Move env_get() to env.hSimon Glass
Move env_get() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-06-19board/freescale/common: secure_boot: Set bootdelay to -2.Udit Agarwal
Uboot prompt must not be available while running secure boot. TO ensure this bootdelay must be set to -2. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-21MPC832XEMDS: Migrate to CONFIG_TARGET_MPC832XEMDSMario Six
Use the proper CONFIG_TARGET_MPC832XEMDS Kconfig option to replace the CONFIG_MPC832XEMDS ad-hoc config option. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-02-19armv8: emc2305: add support for fan controllerMeenakshi Aggarwal
Add support for fan controller emc2305. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Meenakshi Aggarwal <meenakshi.aggarwal@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-02-19armv8: lx2160ardb : Add support for LX2160ARDB platformPriyanka Jain
LX2160ARDB is an evaluation board that supports LX2160A family SoCs. This patch add base support for this board. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Signed-off-by: Yogesh Gaur <yogeshnarayan.gaur@nxp.com> Signed-off-by: Meenakshi Aggarwal <meenakshi.aggarwal@nxp.com> Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com> Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Signed-off-by: Peng Ma <peng.ma@nxp.com> Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> [PK: Sqaush patches from Yinbo Zhu, Peng Ma, Chuanhua Han and re-arrange defconfig] Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2018-12-06board/freescale/vid: Add vdd table for NXP LX2160A SoCPriyanka Jain
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-12-06board/freescale/vid: Add correction for ltc3882 read error.Priyanka Jain
Voltage regulator LTC3882 device has 0.5% voltage read error. So for NXP SoC devices this generally equates to 2mV Update set_voltage_to_LTC for below: 1.Add coorection of upto 2mV in voltage comparison to take care of voltage read error of voltage regulator 2.Add loop max count kept as 100 to avoid infinte loop. Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-08-10armv8: layerscape: move ns_dev[] define from h to c file.Ran Wang
Move ns_dev[] from header file to C file to avoid compiling warning when header file is included by others. Signed-off-by: Ran Wang <ran.wang_1@nxp.com> [YS: rewrite commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2018-06-08board/freescale,lsch3: Add entry for 0.9vPriyanka Jain
As per updated hardware documentation for lsch3 based chips like LS2088A, 0.9v support has been added in possible supported SoC volatges Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-01-23fsl: common: qixis: Add ifc and emmc switching via qixisAshish Kumar
Currently only SD, NAND can be secondary boot sources controlled by FPGA/CPLD via qixis commands. For SoC like LS1088 IFC-NOR can be secondary boot source, while QSPI-NOR is the primary. Add options in qixis to switch to other boot sources including ifc and emmc. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-23common: board_f: vid: Add VID specific API to adjust core voltageRajesh Bhagat
Adds a VID specific API in init_sequence_f and spl code flow namely init_func_vid which is required to adjust core voltage. VID specific code is required in spl, hence moving flag CONFIG_VID out of spl flags. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-23board: common: vid: Add support for LTC3882 voltage regulator chipRajesh Bhagat
Restructures common driver to support LTC3882 voltage regulator chip. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-23Kconfig: Add LTC3882 voltage regulator configRajesh Bhagat
Adds below LTC3882 voltage regulator config: CONFIG_VOL_MONITOR_LTC3882_READ CONFIG_VOL_MONITOR_LTC3882_SET Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-23board: common: vid: Move IR chip specific code in flagRajesh Bhagat
Moves IR chip (IR36021) specific code in flag to resolve compilation issue where it is not present. For example, LS1088A is having a new LTC3882 voltage chip. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-23board: common: vid: Add board specific vdd adjust APIRajesh Bhagat
Adds a board specific API namely board_adjust_vdd which is required to define the board VDD adjust settings. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-23board: common:vid: Add LS1088A VID Supported voltage valuesRajesh Bhagat
Adds below voltage values supported by LS1088A Soc: 1.025V(default), 0.9875V, 0.9750V, 0.9V, 1.0V, 1.0125V, 1.0250V. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-17Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2018-01-17freescale: Ensure common commands are not included in SPL binaryTom Rini
Both the "qixis_reset" and esbc_validate" commands can only be used in full U-Boot so do not build them in SPL. As part of this rework the qixis code to declare things as static and make use of __weak for function aliases. Cc; York Sun <york.sun@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-15configs: SECURE_BOOT: Enable CONFIG_CMD_EXT4_WRITESumit Garg
As part of chain of trust with confidentiality along with distro boot, linux kernel image needs to be stored in encrypted form on ext4 boot partition. So enable CONFIG_CMD_EXT4_WRITE in case of Secure boot on ARM based platforms. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-12board: freescale: common: add pfuze dm codePeng Fan
Add pfuze dm code, this code could be enabled with CONFIG_DM_PMIC_PFUZE100. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-09fsl-lsch2: csu: correct the workaround A-010315Hou Zhiqiang
The implementation of function set_pcie_ns_access() uses a wrong argument. The structure array ns_dev has a member 'ind' which is initialized by CSU_CSLX_*. It should use the 'ind' directly to address the PCIe's CSL register (CSL_base + CSU_CSLX_PCIE*). Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> [YS: Revise commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-01arm64: ls1043ardb: Add distro secure boot supportSumit Garg
Enable validation of boot.scr script prior to its execution dependent on "secureboot" flag in environment. Disable fall back option to nor/qspi boot in case of secure boot. Also enable "secureboot=y" flag in environment for ARM based platforms instead of bootcmd. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Tested-by: Vinitha Pillai <vinitha.pillai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-06-03Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-06-01armv8: layerscape: Make U-Boot EL2 safeYork Sun
When U-Boot boots from EL2, skip some lowlevel init code requiring EL3, including CCI-400/CCN-504, trust zone, GIC, etc. These initialization tasks are carried out before U-Boot runs. This applies to the RAM version image used for SPL boot if PPA is loaded first. Signed-off-by: York Sun <york.sun@nxp.com>
2017-06-01dm: Use dm.h header when driver mode is usedSimon Glass
This header includes things that are needed to make driver build. Adjust existing users to include that always, even if other dm/ includes are present Signed-off-by: Simon Glass <sjg@chromium.org>
