This patch adds new boot 8bit 600x400 bmp logo
who has black background and white words.
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
Fix the build warning in uboot build.
Fix bug of incorrect dereference to periph2 clock pre divider.
Fix incorrect type of maxpackage size assign, even it's
not used at all in fastboot.
Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
- move recovery.h to common inlcude place.
- move supported_reco_envs to soc related, not board related,
- user can change this via configure header,
don't needs this in every board file.
- pass build for all mx5/mx6 android configs.
Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
- add android build config for mx6sl_arm2 board.
- add gpio support for mx6sl
- add boot image support
- add android recovery support
- add fastboot support, but fastboot cannot transfer file.
Signed-off-by Zhang Jiejing <jiejing.zhang@freescale.com>
1. add check asrc register to enter recovery mode,
rather then check the file.
2. fix the boot.img can not fastboot flash function.
3. consolidate and cleanup fastboot code.
4. clean up many build warnning message.
For example: The soc rev on i.mx6dl rev 1.0 not print correctly:
CPU: Freescale i.MX 6 family 0.0V at 792 MHz
This patch help u-boot print out the SOC revision correctly:
CPU: Freescale i.MX6 family TO1.0 at 792 MHz
Signed-off-by: Jason Liu <r64343@freescale.com>
- Different chip will include different head file, so add macro
define to limit the use range.
Signed-off-by: Fugang Duan <B38611@freescale.com>
- Add fsl_system_rev to distinguish chip ID and board reversion.
- Add some api:
mx6_chip_is_dq()
mx6_chip_is_dl()
mx6_chip_is_solo()
mx6_chip_is_sololite()
mx6_board_is_reva()
mx6_board_is_revb()
mx6_board_is_revc()
Support booti command which can boot from a boot.img
boot.img is a zImage + ramdisk.img + bootargs + boot addr
which include these info can be used to avoid mis match between
kernel and ramdisk, also can avoid commit to chagne default
bootargs.
For example:
> booti mmc1
command will read the boot.img from 1M offset,
and then parser the bootargs and ramdisk
then do the boot from that zImage.
> booti mmc1 recovery
will going to read the recovery's partition no
and offset and boot from recovery image.
this recovery image also a zImage + ramdisk
bootargs:
if uboot have define a env var 'bootargs', booti command
will use this bootargs as kernel cmdline
if you want use boot.img 's bootargs, just type:
> setenv bootargs
in uboot to clear the bootargs in uboot env.
our default uboot env will be NULL in config file.
also, android use boot.img to support OTA.
Correct the GPL license
1) IOMUX/backlight support for CLAA WVGA LCD panel.
2) Add video mode for CLAA WVGA LCD panel.
3) Support IPU di1 interface for framebuffer.
4) Enhance IPU driver.
5) Add freescale 600x400 8BPP BMP logo.
Signed-off-by: Terry Lv <R65388@freescale.com>
Signed-off-by: Liu Ying <b17645@freescale.com>
This change make a bootable default setting of MX53 EVK and MX51 BBG board,
the old default setting is too old to boot android system up.
Also add the recovery command in the env strings, if you want
to boot to recovery mode with mx53_evk, you can just :
> run bootcmd_android_recovery
This command will boot android into recovery mode.
Also fix MX51 can't see UI in recovery mode.
Add android recovery mode support for mx53.
Signed-off-by: Terry Lv <r65388@freescale.com>
Move the android recovery codes into common/recovery.c.
Cut the keypad detecting time. Now we only need detect
there's POWER and HOME key pressing at the time scanning
keyboard matrix. So user must hold these two keys when bootup to
enter recovery mode. This can reduce the uboot boot time with
recovery mode configured.
Later /cache file checking for recovery command should be merged
into the common/recovery.c
The pixis code used in8/out8 all over the place. Replace it with
in_8/out_8 macros.
sys_eeprom.c: In function 'do_mac':
sys_eeprom.c:323: warning: dereferencing type-punned pointer will break strict-aliasing rules
sys_eeprom.c: In function 'mac_read_from_eeprom':
sys_eeprom.c:395: warning: dereferencing type-punned pointer will break strict-aliasing rules
We support up to 8 mac addresses in system eeprom, so we define the macro
MAX_NUM_PORTS to limit the mac_count to 8, and update the number of ethxaddr
according to mac_count.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
These were left in accidentally, and are not really useful unless the
code is as broken as it was when it was being developed.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The device tree's PHY addresses need to be fixed up if we're using the
SGMII Riser Card.
The 8572, 8536, and 8544 DS boards were modified to call this function.
Code idea taken from Liu Yu <yu.liu@freescale.com>
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
The pixis sgmii command depend on the FPGA support on the board, some 85xx
boards support SGMII riser card but did not support this command, define
CONFIG_PIXIS_SGMII_CMD for those boards which support the sgmii command.
Not like 8544, 8572 has 4 eTsec so that the other two's pixis bits
are not supported by 8544. Therefor, define PIXIS_VSPEED2_MASK and
PIXIS_VCFGEN1_MASK in header file for both boards.
Signed-off-by: Liu Yu <yu.liu@freescale.com>
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
When aligning malloc()ed screen_base, invalid offset was added.
This not only caused misaligned result (which did not cause hardware
misbehaviour), but - worse - caused screen_base + smem_len to
be out of malloc()ed space, which in turn caused breakage of
futher malloc()/free() operation.
This patch fixes screen_base alignment.
Also this patch makes memset() that cleans framebuffer to be executed
on first initialization of diu, not only on re-initialization. It looks
correct to clean the framebuffer instead of displaying random garbage;
I believe that was disabled only because that memset caused breakage
of malloc/free described above - which no longer happens with the fix
described above.
Signed-off-by: Nikita V. Youshchenko <yoush@debian.org>
get_cpu_board_revision() returned board revision based on information stored
in global static struct eeprom. It should instead use one from local struct
board_eeprom, to which the data is actually read from EEPROM. The bug led to
system hang after printing L1 cache information on U-Boot startup. The problem
was observed on MPC8555CDS system and possibly affects other Freescale MPC85xx
boards using CFG_I2C_EEPROM_CCID.
The change has been successfully tested on MPC8555CDS system.
Signed-off-by: Rafal Czubak <rcz@semihalf.com>
The new sys_eeprom.c supports both the old CCID EEPROM format and the new NXID
format, and so it obsoletes board/freescale/common/cds_eeprom.c. Freescale
86xx boards already use sys_eeprom.c, so this patch migrates the remaining
Freescale 85xx boards to use it as well. cds_eeprom.c is deleted.
The 8544DS and 8572DS platforms support an optional SGMII riser card to
expose ethernet over an SGMII interface. Once the card is in, it is also
necessary to configure the board such that it uses the card, rather than
the on-board ethernet ports. This can either be done by flipping dip switches
on the motherboard, or by modifying registers in the pixis. Either way
requires a reboot.
This adds a command to allow users to choose which ports are routed through
the SGMII card, and which through the onboard ports. It also allows users
to revert to the current switch settings.
This code does not work on the 8572, as the PIXIS is different.
The 8544DS and 8572DS systems have an optional SGMII riser card which
exposes new ethernet ports which are connected to the eTSECs via an
SGMII interface. The SGMII PHYs for this board are offset from the standard
PHY addresses, so this code modifies the passed in tsec_info structure to
use the SGMII PHYs on the card, instead.
Update the sys_eeprom.c file to handle both NXID and CCID EEPROM formats. The
NXID format replaces the older CCID format, but it's important to support both
since most boards out there still use the CCID format. This change is in
preparation for using one file to handle both formats. This will also unify
EEPROM support for all Freescale 85xx and 86xx boards.
Also update the 86xx board header files to use the standard CFG_I2C_EEPROM_ADDR
instead of ID_EEPROM_ADDR.
Remove DPRINTF macro and replace it with generic debug macro.
Signed-off-by: York Sun <yorksun@freescale.com>
The clock divider has different format in 5121 and 8610. This patch moves it to
board specific code.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Each file that can be built here now follows some
CONFIG_ option so that they are appropriately built
or not, as needed. And CONFIG_ defines were added
to various board config files to make sure that happens.
The other board/freescale/*/Makefiles no longer need
to reach up and over into ../common to build their
individually needed files any more.
Boards that are CDS specific were renamed with cds_ prefix.
sys_eeprom.c:82:9: warning: unknown escape sequence '\/'
- Fix EEPROM_data structure definition according to System EEPROM Data Format.
- Read MAC addresses from EEPROM to ethXaddr before saving ethXaddr to
bd->bi_ethaddr.
Before, the order of arguments to the pixis_reset
command needed to be supplied in a hard-coded order.
Generalize the command parsing to allow any order.
Signed-off-by: James Yang <james.yang@freescale.com>
Acked-by: Jon Loeliger <jdl@freescale.com>
Convert the board/freescale/common/Makefile to use
CONFIG_* options to select which files to conditionally
compile into the board/freescale/common library rather
than conditionally compiling entire files.
Now handles::
CONFIG_FSL_PIXIS
CONFIG_FSL_DIU_FB
CONFIG_PQ_MDS_PIB
CONFIG_ID_EEPROM is introduced until CFG_ID_EEPROM is gone.
Minor path corrections needed to ensure buildability.
These two structures are still needed during the
initialization and setup of the DIU hardware.
So move them to the fsl_diu_fb.h file for now.
Official "blah".
Noticed-by: York Sun <yorksun@freescale.com>
Basically, refactor the CFG_PIXIS_VBOOT_MASK values
into the separate board config files.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
1280x1024 and 1024x768 @ 32 bpp are supported now.
DVI, Single-link LVDS, Double-link LVDS are all supported.
Environmental variable "monitor" is used to specify monitor port.
A new command "diufb" is introduced to reinitialize monitor
and display a BMP file in the memory. So far, 1-bit, 4-bit,
8-bit and 24-bit BMP formats are supported.
diufb init
- initialize the diu driver
Enable the port specified in the environmental variable "monitor"
diufb addr
- display bmp file in memory.
The bmp image should be no bigger than the resolution, 1280x1024
for DVI and double-link LVDS, 1024x768 for single-link LVDS.
Note, this driver allocate memory but doesn't free it after use
It is written on purpose -- to avoid a failure of reallocation
due to memory fragement.
ECC of DDR is disabled for DIU performance. L2 data cache is also disabled.
Signed-off-by: Jon loeliger <jdl@freescale.com>
This Freescale logo is a 340 x 128 x 4bpp BMP file
that can be displayed by the DIU Framebuffer driver.
