path: root/board/freescale/common/vsc3316_3308.c
2013-08-20powerpc/common/vsc3316: remove const from vsc3316_config parameter defineShaohui Xie
Since the parameters need to be modified according to different Serdes protocols at runtime, the const will block this. Also remove const from arrays define used by vsc3316_config. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2012-10-22board/freescale/common: VSC3316/VSC3308 initialization codeShaveta Leekha
Add code for configuring VSC3316/3308 crosspoint switches Add README to understand the APIs - VSC 3316/3308 is a low-power, low-cost asynchronous crosspoint switch capable of data rates upto 11.5Gbps. VSC3316 has 16 input and 16 output ports whereas VSC3308 has 8 input and 8 output ports. Programming of these devices are performed by two-wire or four-wire serial interface. Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
