path: root/board/freescale/common/ls102xa_stream_id.c
2016-06-03board: ls102xa: Fix ICID setupVincent Siles
LS102A ref manual dictates that ICID have to be written to the MSB of the ICID register, not to the LSB. Signed-off-by: Vincent Siles <vincent.siles@provenrun.com>
2016-05-18arm: uniform usage of u32 in ls102x caam configVincent Siles
Mix usage of uint32_t and u32 fixed in favor of u32. Signed-off-by: Vincent Siles <vincent.siles@provenrun.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-18arm: Fix SCFG ICID reg addressesVincent Siles
On the LS102x boards, in order to initialize the ICID values of masters, the dev_stream_id array holds absolute offsets from the base of SCFG. In ls102xa_config_ssmu_stream_id, the base pointer is cast to uint32_t * before adding the offset, leading to an invalid address. Casting it to void * solves the issue. Signed-off-by: Vincent Siles <vincent.siles@provenrun.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-02-24arm: ls1021x: Add support for initializing CAAM's stream idAlison Wang
There 4 JRs, 4 RTICs and 8 DECOs, and set them the same stream id for using the same SMMU3 on LS1021A. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11ARM: ls102xa: Setting device's stream id for SMMUs.Xiubo Li
LS1 has 4 SMMUs for address translation of the masters. All the SMMUs' stream IDs are 8-bit. The address translation depends on the stream ID of the incoming transaction. Each master has unique stream ID assigned to it and is configurable through SCFG registers. The stream ID for the masters is identical and share the same register field of STREAM ID registers. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
