path: root/board/freescale/common/ics307_clk.h
2011-11-11powerpc/mpc85xx: Set SYSCLK to the required frequencyJerry Huang
For ICS307-02, there is one general expression to generate SYSCLK: CLK1Frequency = InputFrequency * 2 * (VDW + 8) / ((RDW + 2) * OD) If we want the required frequency for SYSCLK, we must find one solution to generate this frequency, this solution includes VDW, RDW and OD. For OD, there are only eight option value: 10, 2, 8, 4, 5, 7, 3, 6. For RDW, the range is 1 to 127. For VDW, the range is 4 to 511. First, we use one OD, RDW and required SYSCLK to calculate the VDW, if VDW is in it's range, we will calculate the CLK1Frequency with the OD, RDW and VDW calculated, and we will check this percent (CLK1Frequency / required SYSCLK), and the precision is 1/1000. if the percent is less than 1/1000, we think the CLK1Frequency is we want. Otherwise, We will continue to calculate it with the next OD and RDW. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16Move ICS CLK chip frequency calculation code into a common board libraryKumar Gala
We have several boards that use the same ICS307 CLK chip to drive the System clock and DDR clock. Move the code into a common location so we share it. Convert the P2020DS board as the first to use the new common ICS307 code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Timur Tabi <timur@freescale.com>
