Move common code to the fsl_diu_fb.c file and remove obsolete
code from board files (aria, mpc8610hpcd and pdm360ng).
Move fsl_diu_fb.h file to the include directory.
features
The Freescale MPC8610 and MPC5121 DIU code had re-implement two features that already
existed in U-Boot: bitmap drawing and top-of-screen logo (CONFIG_VIDEO_LOGO).
So delete the 8610-specific code and use the built-in features instead.
These two structures are still needed during the
initialization and setup of the DIU hardware.
So move them to the fsl_diu_fb.h file for now.
Official "blah".
Noticed-by: York Sun <yorksun@freescale.com>
1280x1024 and 1024x768 @ 32 bpp are supported now.
DVI, Single-link LVDS, Double-link LVDS are all supported.
Environmental variable "monitor" is used to specify monitor port.
A new command "diufb" is introduced to reinitialize monitor
and display a BMP file in the memory. So far, 1-bit, 4-bit,
8-bit and 24-bit BMP formats are supported.
diufb init
- initialize the diu driver
Enable the port specified in the environmental variable "monitor"
diufb addr
- display bmp file in memory.
The bmp image should be no bigger than the resolution, 1280x1024
for DVI and double-link LVDS, 1024x768 for single-link LVDS.
Note, this driver allocate memory but doesn't free it after use
It is written on purpose -- to avoid a failure of reallocation
due to memory fragement.
ECC of DDR is disabled for DIU performance. L2 data cache is also disabled.
Signed-off-by: York Sun <yorksun@freescale.com>
Signed-off-by: Jon loeliger <jdl@freescale.com>
