2008-09-10 | rename CFG_ENV macros to CONFIG_ENV | Jean-Christophe PLAGNIOL-VILLARD | |
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> | |||
2008-09-10 | rename CFG_ENV_IS_IN_FLASH in CONFIG_ENV_IS_IN_FLASH | Jean-Christophe PLAGNIOL-VILLARD | |
2003-05-30 | * Get (mostly) rid of CFG_MONITOR_LEN definition; compute real lengthLABEL_2003_05_30_1450 | wdenk | |
instead CFG_MONITOR_LEN is now only used to determine _at_compile_ _time_ (!) if the environment is embedded within the U-Boot image, or in a separate flash sector. * Cleanup CFG_DER #defines in config files (wd maintained only) | |||
2002-10-25 | Initial revision | wdenk | |
