path: root/board/firefly
2020-08-21rockchip: firefly-rk3288: Fix the code support for SPL_LEDKever Yang
Fix the build error for the wrong code when CONFIG_SPL_LED is enabled. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2020-07-22rockchip: roc-rk3399-pc: Set LED only during POR and pwr_key=yJagan Teki
ROC-RK3399-PC has specific set of configurations for on-board led setup. Due to easiness for user to know the state of the board roc-rk339-pc board code will setup the low power led on/off, and waiting for user to press power key and then glow full power led. All this needs to happen only during power-on-reset not for soft reset or WDT. Also, it is not a proper usage to ask the user to press the Power key if the board connected remotely, so add the environment variable 'pwr_key' to check as well. So, user need to press Power key only - during POR - pwr_key=y Tested-by: Suniel Mahesh <sunil@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-07-22rockchip: roc-rk3399-pc: Add custom led_setup()Jagan Teki
roc-rk3399-pc has some specific requirements to support LEDS, environment. board detection and etc prior to U-Boot proper. So as of now SPL would be a better stage for these custom board requirements to support unlike TPL. Adding few of these custom requirements like LEDS in TPL would require extra code pulling and also the size of TPL can grow. So, this patch moves the leds code from TPL into SPL Board init led_setup code. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> (split tpl.c change as separate patch) Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2020-05-18common: Drop linux/bitops.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-01rk3399: Add ROC-RK3399-PC Mezzanine boardSuniel Mahesh
Add Firefly ROC-RK3399-PC Mezzanine board which is an extension board on top of roc-rk3399-pc. Will drop the separate defconfig file, once we support the board detection at runtime. Signed-off-by: Suniel Mahesh <sunil@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-04-29rockchip: board: roc-pc-rk3399: Remove support for push buttonSuniel Mahesh
In case of a power interruption, human intervention is required which is not desirable if the device is installed at a remote location. Drop yellow LED as it is not much of use. Keep red LED(diy-led) as it is, to indicate board in full power mode. Signed-off-by: Suniel Mahesh <sunil@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-02-19board: roc-pc-rk3399: Add support for onboard LED's and push button to ↵Suniel Mahesh
indicate power mode Added support for onboard LED's and push button. When powered board will be in low power mode(yellow LED), on button press, board enters full power mode (red LED) and boots u-boot. Signed-off-by: Suniel Mahesh <sunil@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-02-19rockchip: rk3399: split roc-pc-rk3399 out of evb_rk3399Suniel Mahesh
roc-pc-rk3399 board has one user button & three user LED's. Currently we don't have any code support for these devices. Since button and LED's are specific to roc-pc-rk3399 board, split it into its own board file and add code support here. Signed-off-by: Suniel Mahesh <sunil@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-17common: Move hang() to the same header as panic()Simon Glass
At present panic() is in the vsprintf.h header file. That does not seem like an obvious choice for hang(), even though it relates to panic(). So let's put hang() in its own header. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Migrate a few more files] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-17rockchip: rk3308: Add support for ROC-RK3308-CC boardAndy Yan
ROC-RK3308-CC is a rk3308 based board designed by Firelfy, with eMMC and 256MB DDR3 and RTL8188 Wifi on board. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-29rockchip: rk3288: move setup_led() to firefly-rk3288Kever Yang
Only firefly-rk3288 has the dts node "u-boot,boot-led", while CONFIG_SPL_LED is not enable, move code to firefly-rk3288 now in case someone need this code. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2015-09-02rockchip: Add basic support for firefly-rk3288Simon Glass
The Firefly RK3288 is a suitable target board for initial mainline Rockchip support. It includes a good set of peripherals, a recent SoC and it is readily available. This adds only some basic files required to allow the baord to display a serial message in SPL and hang. Signed-off-by: Simon Glass <sjg@chromium.org>
