path: root/board/fads
2009-07-23unify HOST_CFLAGS and HOSTCFLAGSMike Frysinger
The top build system sets up HOSTCFLAGS a bit and exports it, but other places use HOST_CFLAGS instead. Unify the two as HOSTCFLAGS so that the values stay in sync. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-07-11Fix some more print() format errors.Wolfgang Denk
2008-04-13Add CONFIG_MII_INIT support to related boardsTsiChung Liew
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in cmd_init.c. Add CONFIG_MII_INIT to board configuration files that use mii_init() in cmd_init.c. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-13ppc: Get rid of unused machine type definitionsWolfgang Denk
2007-09-16TQM8xx[LM]: Fix broken environment alignment.Wolfgang Denk
With recent toolchains, the environment sectors were no longer aligned to sector boundaries. The reason was a combination of two bugs: 1) common/environment.c assumed that CONFIG_TQM8xxL would be defined for all TQM8xxL and TQM8xxM boards. But "include/common.h", where this gets defined, is not included here (and cannot be included without causing lots of problems). Added a new #define CFG_USE_PPCENV for all boards which really want to put the environment is a ".ppcenv" section. 2) The linker scripts just include environment.o, silently assuming that the objects in that file are really in the order in which they are coded in the C file, i. e. "environment" first, then "redundand_environment", and "env_size" last. However, current toolchains (GCC-4.x) reorder the objects, causing the environment data not to start on a flash sector boundary: Instead of: we got: 40008000 T environment 40008000 T env_size 4000c000 T redundand_environment 40008004 T redundand_environment 40010000 T env_size 4000c004 T environment Note: this patch fixes just the first part, and cures the alignment problem by making sure that "env_size" gets placed correctly. However, we still have a potential issue because primary and redundant environment sectors are actually swapped, i. e. we have now: 40008000 T redundand_environment 4000c000 T environment 40010000 T env_size This shall be fixed in the next version. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-16mpc885ads: Don't define CONFIG_BZIP2.Scott Wood
bzip2 requires a significant chunk of malloc space, and there isn't enough room on mpc885ads (with only 8MB RAM) for both bzip2's malloc area and a downloaded image at 0x400000. Signed-off-by: Scott Wood <scottwood@freescale.com>
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-09board/[f-l]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-07include/configs: Use new CONFIG_CMD_* in various A* named board config files.Jon Loeliger
Since ADS860.h includes "board/fads/fads.h" with ramifications on the CONFIG_COMMAND treatment, it too has to be adjusted to exclude already configured commands in this same commit. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-07-21More code cleanupWolfgang Denk
2006-07-10Major PCMCIA Cleanup to make code better readable and maintainable.Wolfgang Denk
Notes: - Board-dependend code for RPXLITE and RPXCLASSIC-based boards placed to the drivers/rpx_pmcia.c file to avoid duplication. Same for TQM8xx-based boards (drivers/tqm8xx_pmcia.c). - drivers/i82365.c has been split into two parts located at board/atc/ti113x.c and board/cpc45/pd67290.c (ATC and CPC45 are the only boards using CONFIG_82365). - Changes were tested for clean build and *very* *few* boards.
2006-03-12Switch MPC86xADS and MPC885ADS boards to use cpuclk environmentWolfgang Denk
variable to set clock Patch by Yuli Barcohen, 05 Jun 2005
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2004-06-09Patch by Yuli Barcohen, 09 Jun 2004:wdenk
Add support for 8MB flash SIMM and JFFS2 file system on Motorola FADS board and its derivatives (MPC86xADS, MPC885ADS).
2004-06-06* Patch by Dave Peverley, 30 Apr 2004:wdenk
Add support for OMAP730 Perseus2 Development board * Patch by Alan J. Luse, 29 Apr 2004: Fix flash chip-select (OR0) option register setting on FADS boards. * Patch by Alan J. Luse, 29 Apr 2004: Report MII network speed and duplex setting properly when auto-negotiate is not enabled. * Patch by Jarrett Redd, 29 Apr 2004: Fix hang on reset on Ocotea board due to flash in wrong mode.
2004-06-06Patch by Yuli Barcohen, 19 Apr 2004:wdenk
- Rename DUET_ADS to MPC885ADS - Rename CONFIG_DUET to CONFIG_MPC885_FAMILY - Rename CONFIG_866_et_al to CONFIG_MPC866_FAMILY - Clean up FADS family port to use the new defines
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2004-01-04* Fix problems caused by Robert Schwebel's cramfs patchwdenk
* Patch by Scott McNutt, 02 Jan 2004: Add support for the Nios Active Serial Memory Interface (ASMI) on Cyclone devices * Patch by Andrea Marson, 16 Dec 2003: Add support for the PPChameleon ME and HI modules * Patch by Yuli Barcohen, 22 Dec 2003: Add support for Motorola DUET ADS board (MPC87x/88x)
2003-12-07* Patch by Yuli Barcohen, 3 Dec 2003:wdenk
"revive" U-Boot support for old Motorola MPC860ADS board * Patch by Cam(ilo?), 03 Dec 2003: make examples build even with broken Montavista objcopy * Patch by Pavel Bartusek, 27 Nov 2003: fix conversion problem with "bootretry" evironment variable
2003-07-17* Patch by Martin Krause, 17 Jul 2003:wdenk
add delay to get I2C working with "imm" command and s3c24x0_i2c.c * Patch by Richard Woodruff, 17 July 03: - Fixed bug in OMAP1510 baud rate divisor settings. * Patch by Nye Liu, 16 July 2003: MPC860FADS fixes: - add MPC86xADS support (uses MPC86xADS.h) - add 866P/T core support (also MPC859T/MPC859DSL/MPC852T) o PLPRCR changes o BRG changes (EXTAL/XTAL restricted to 10MHz) o don't trust gclk() software measurement by default, depend on CONFIG_8xx_GCLK_FREQ - add DRAM SIMM not installed detection - use more "correct" SDRAM initialization sequence - allow different SDRAM sizes (8xxADS has 8M) - default DER is 0 - remove unused MAMR defines from FADS860T.h (all done in fads.c) - rename MAMR/MBMR defines to be more consistent. Should eventually be merged into MxMR to better reflect the PowerQUICC datasheet. * Patch by Yuli Barcohen, 16 Jul 2003: support new Motorola PQ2FADS-ZU evaluation board which replaced MPC8260ADS and MPC8266ADS
2003-05-22* Patch by Dave Ellis, 22 May 2003:LABEL_2003_05_23_0055wdenk
Fix problem with only partially cleared .bss segment * Patch by Rune Torgersen, 12 May 2003: get PCI to work on a MPC8266ADS board; incorporate change to cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
2001-04-28Initial revisionwdenk
2000-12-14Initial revisionwdenk
