path: root/board/fads/fads.h
2014-07-07mpc8xx: remove fads board supportMasahiro Yamada
These boards are old enough and have no maintainers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18powerpc: remove ADS860, FADS823, FADS850SAR, FADS860T supportMasahiro Yamada
Enough time has passed since these boards were moved to Orphan. Remove. - Remove include/configs/{ADS860.h,FADS823.h,FADS850SAR.h,FADS860T.h} - Cleanup defined(CONFIG_ADS), defined(CONFIG_MPC823FADS), defined(CONFIG_MPC850SAR), defined(CONFIG_SYS_DAUGHTERBOARD) - Remove the entries from boards.cfg Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19config: remove platform CONFIG_SYS_HZ definition part 3Masahiro Yamada
This commit removes platform CONFIG_SYS_HZ definition for the remainders of part1 (commit cdb23792) and part2 (commit f232950f). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-04-13Add CONFIG_MII_INIT support to related boardsTsiChung Liew
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in cmd_init.c. Add CONFIG_MII_INIT to board configuration files that use mii_init() in cmd_init.c. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-13ppc: Get rid of unused machine type definitionsWolfgang Denk
2007-09-16TQM8xx[LM]: Fix broken environment alignment.Wolfgang Denk
With recent toolchains, the environment sectors were no longer aligned to sector boundaries. The reason was a combination of two bugs: 1) common/environment.c assumed that CONFIG_TQM8xxL would be defined for all TQM8xxL and TQM8xxM boards. But "include/common.h", where this gets defined, is not included here (and cannot be included without causing lots of problems). Added a new #define CFG_USE_PPCENV for all boards which really want to put the environment is a ".ppcenv" section. 2) The linker scripts just include environment.o, silently assuming that the objects in that file are really in the order in which they are coded in the C file, i. e. "environment" first, then "redundand_environment", and "env_size" last. However, current toolchains (GCC-4.x) reorder the objects, causing the environment data not to start on a flash sector boundary: Instead of: we got: 40008000 T environment 40008000 T env_size 4000c000 T redundand_environment 40008004 T redundand_environment 40010000 T env_size 4000c004 T environment Note: this patch fixes just the first part, and cures the alignment problem by making sure that "env_size" gets placed correctly. However, we still have a potential issue because primary and redundant environment sectors are actually swapped, i. e. we have now: 40008000 T redundand_environment 4000c000 T environment 40010000 T env_size This shall be fixed in the next version. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-16mpc885ads: Don't define CONFIG_BZIP2.Scott Wood
bzip2 requires a significant chunk of malloc space, and there isn't enough room on mpc885ads (with only 8MB RAM) for both bzip2's malloc area and a downloaded image at 0x400000. Signed-off-by: Scott Wood <scottwood@freescale.com>
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-09board/[f-l]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-07include/configs: Use new CONFIG_CMD_* in various A* named board config files.Jon Loeliger
Since ADS860.h includes "board/fads/fads.h" with ramifications on the CONFIG_COMMAND treatment, it too has to be adjusted to exclude already configured commands in this same commit. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-07-21More code cleanupWolfgang Denk
2006-03-12Switch MPC86xADS and MPC885ADS boards to use cpuclk environmentWolfgang Denk
variable to set clock Patch by Yuli Barcohen, 05 Jun 2005
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2004-06-09Patch by Yuli Barcohen, 09 Jun 2004:wdenk
Add support for 8MB flash SIMM and JFFS2 file system on Motorola FADS board and its derivatives (MPC86xADS, MPC885ADS).
2004-06-06Patch by Yuli Barcohen, 19 Apr 2004:wdenk
- Rename DUET_ADS to MPC885ADS - Rename CONFIG_DUET to CONFIG_MPC885_FAMILY - Rename CONFIG_866_et_al to CONFIG_MPC866_FAMILY - Clean up FADS family port to use the new defines
2004-01-04* Fix problems caused by Robert Schwebel's cramfs patchwdenk
* Patch by Scott McNutt, 02 Jan 2004: Add support for the Nios Active Serial Memory Interface (ASMI) on Cyclone devices * Patch by Andrea Marson, 16 Dec 2003: Add support for the PPChameleon ME and HI modules * Patch by Yuli Barcohen, 22 Dec 2003: Add support for Motorola DUET ADS board (MPC87x/88x)
2000-12-14Initial revisionwdenk
