The EXBITGEN board has not been maintained for a long time; it has
build problems, but no hardware is available any more for testing.
Drop support for this board.
Modify all existing *.c files to use the new register names
as seen in the AMCC manuals.
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
The latest PPC4xx register cleanup patch missed some SDRAM defines.
This patch now changes lower case UIC defines to upper case. Also
some names are changed to match the naming in the IBM/AMCC users
manuals (e.g. mem_mcopt1 -> SDRAM0_CFG).
This patch cleans up multiple issues of the 4xx register (mostly
DCR, SDR, CPR, etc) definitions:
- Change lower case defines to upper case (plb4_acr -> PLB4_ACR)
- Change the defines to better match the names from the
user's manuals (e.g. cprpllc -> CPR0_PLLC)
- Removal of some unused defines
Please test this patch intensive on your PPC4xx platform. Even though
I tried not to break anything and tested successfully on multiple
4xx AMCC platforms, testing on custom platforms is recommended.
It was brought to our attention that U-Boot contains code derived from the
IBM OpenBIOS source code originally provided with some of the older PowerPC
4xx development boards. As a result, the original license of this code has
been carried in the various files for a number of years in the U-Boot project.
IBM is dual-licensing the IBM code contributions already present in U-Boot
under either the terms of the GNU General Public License version 2, or the
original code license already present.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
- Allow to call sysmon function interactively
- PIC on LWMON board needs delay after power-on
- Add missing RSR definitions for MPC8xx
- Improve log buffer handling: guarantee clean reset after power-on
- Add support for EXBITGEN board
- Add support for SL8245 board
