path: root/board/evb64260
2011-01-09miiphy: convert to linux/mii.hMike Frysinger
The include/miiphy.h header duplicates a lot of things from linux/mii.h. So punt all the things that overlap to keep the API simple and to make merging between U-Boot and Linux simpler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-2774xx_7xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-08-09miiphy: constify device nameMike Frysinger
The driver name does not need to be writable, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-06-30Merge branch 'master' into nextWolfgang Denk
2010-06-29Fix compiler warnings for EVB64260, P3G4 and ZUMAAnatolij Gustschin
Fix following warnings: $ ./MAKEALL EVB64260 P3G4 ZUMA Configuring for EVB64260 board... mpsc.c: In function 'mpsc_putchar_early': mpsc.c:121: warning: dereferencing type-punned pointer will break strict-aliasing rules mpsc.c:127: warning: dereferencing type-punned pointer will break strict-aliasing rules ... Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-06-23Get rid of bogus CONFIG_SYS_BUS_HZ and CONFIG_SYS_CONFIG_BUS_CLK definitionsWolfgang Denk
CONFIG_SYS_BUS_HZ has not really been used anywhere except to be redined as CONFIG_SYS_BUS_CLK; in addition, the mpc7448hpc2 had the bogus CONFIG_SYS_CONFIG_BUS_CLK setting which duplicated the funtionality. Change all this to use CONFIG_SYS_BUS_CLK consistently. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Frank Gottschling <fgottschling@eltec.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Eran Man <eran@nbase.co.il> Cc: Stefan Roese <sr@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-18Fix build errors after making flash_get_info() non-staticWolfgang Denk
Fix for these build problems: error: static declaration of 'flash_get_info' follows non-static declaration Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-09evb64260: fix "cast to pointer from integer of different size" warningsWolfgang Denk
2008-09-02Moved initialization of GT6426x Ethernet controller to board_eth_init()Ben Warren
Affected boards: EVB64260 P3G4 ZUMA Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[d-e]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-10-09Coding style cleanupWolfgang Denk
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-05-03* Patch by Stefan Roese, 03 May 2005:stroese
Update for P3G4 Fix problems in cmd_universe.c
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-02-23* CVS add missing fileswdenk
* Cleanup compiler warnings * Fix problem with side effects in macros in include/usb.h * Patch by David Benson, 13 Nov 2003: bug 841358 - fix TFTP download size limit * Fixing bug 850768: improper flush_cache() in load_serial() * Fixing bug 834943: MPC8540 - missing volatile declarations * Patch by Stephen Williams, 09 Feb 2004: Add support for Xilinx SystemACE chip: - New files common/cmd_ace.c and include/systemace.h - Hook systemace support into cmd_fat and the partition manager * Patch by Travis Sawyer, 09 Feb 2004: Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
2004-02-12Last minute fixes / cleanup.U-Boot-1_0_2wdenk
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2003-10-29* Prepare for releasewdenk
* Fix problems in memory test on some boards (which was not non-destructive as intended) * Patch by Gary Jennejohn, 28 Oct 2003: Change fs/fat/fat.c to put I/O buffers in BSS instead on the stack to prevent stack overflow on ARM systems
