path: root/board/evb64260
2011-11-23i2c: Codingstyle cleanup for i2c evb64260 board driverHeiko Schocher
There are some magic constants in this drivers, which I cannot fixup ... Eran, can you help here? Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Eran Man <eran@nbase.co.il>
2011-11-16board/evb64260/zuma_pbb_mbox.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: zuma_pbb_mbox.c: In function 'zuma_mbox_dump': zuma_pbb_mbox.c:115:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] zuma_pbb_mbox.c:117:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-16board/evb64260/zuma_pbb_mbox.c: CodingStyle cleanupWolfgang Denk
Make (mostly) checkpatch-clean Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-16board/evb64260/sdram_init.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: sdram_init.c: In function 'setup_sdram_common': sdram_init.c:333:49: warning: variable 'ecc' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'setup_sdram': sdram_init.c:410:13: warning: variable 'check' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-16board/evb64260/eth.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: eth.c: In function 'gt6426x_handle_SMI': eth.c:130:15: warning: variable 'psr' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-16board/evb64260/evb64260.c: Fix GC 4.6 build warningWolfgang Denk
Fix: evb64260.c: In function 'debug_led': evb64260.c:363:6: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-16board/evb64260/i2c.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: i2c.c: In function 'i2c_init': i2c.c:23:15: warning: variable 'actualFreq' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Eran Man <eran@nbase.co.il> Acked-by: Heiko Schocher <hs@denx.de>
2011-11-16board/evb64260/i2c.c: Coding Style cleanupWolfgang Denk
Make checkpatch-clean Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Eran Man <eran@nbase.co.il>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-28cleanup: Fix typos and misspellings in various files.Mike Williams
Recieve/Receive recieve/receive Interupt/Interrupt interupt/interrupt Addres/Address addres/address Signed-off-by: Mike Williams <mike@mikebwilliams.com>
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-01-09miiphy: convert to linux/mii.hMike Frysinger
The include/miiphy.h header duplicates a lot of things from linux/mii.h. So punt all the things that overlap to keep the API simple and to make merging between U-Boot and Linux simpler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-2774xx_7xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-08-09miiphy: constify device nameMike Frysinger
The driver name does not need to be writable, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-06-30Merge branch 'master' into nextWolfgang Denk
2010-06-29Fix compiler warnings for EVB64260, P3G4 and ZUMAAnatolij Gustschin
Fix following warnings: $ ./MAKEALL EVB64260 P3G4 ZUMA Configuring for EVB64260 board... mpsc.c: In function 'mpsc_putchar_early': mpsc.c:121: warning: dereferencing type-punned pointer will break strict-aliasing rules mpsc.c:127: warning: dereferencing type-punned pointer will break strict-aliasing rules ... Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-06-23Get rid of bogus CONFIG_SYS_BUS_HZ and CONFIG_SYS_CONFIG_BUS_CLK definitionsWolfgang Denk
CONFIG_SYS_BUS_HZ has not really been used anywhere except to be redined as CONFIG_SYS_BUS_CLK; in addition, the mpc7448hpc2 had the bogus CONFIG_SYS_CONFIG_BUS_CLK setting which duplicated the funtionality. Change all this to use CONFIG_SYS_BUS_CLK consistently. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Frank Gottschling <fgottschling@eltec.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Eran Man <eran@nbase.co.il> Cc: Stefan Roese <sr@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-18Fix build errors after making flash_get_info() non-staticWolfgang Denk
Fix for these build problems: error: static declaration of 'flash_get_info' follows non-static declaration Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-09evb64260: fix "cast to pointer from integer of different size" warningsWolfgang Denk
2008-09-02Moved initialization of GT6426x Ethernet controller to board_eth_init()Ben Warren
Affected boards: EVB64260 P3G4 ZUMA Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[d-e]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-10-09Coding style cleanupWolfgang Denk
