path: root/board/evb64260/flash.c
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2009-02-18Fix build errors after making flash_get_info() non-staticWolfgang Denk
Fix for these build problems: error: static declaration of 'flash_get_info' follows non-static declaration Signed-off-by: Wolfgang Denk <wd@denx.de>
2003-10-29* Prepare for releasewdenk
* Fix problems in memory test on some boards (which was not non-destructive as intended) * Patch by Gary Jennejohn, 28 Oct 2003: Change fs/fat/fat.c to put I/O buffers in BSS instead on the stack to prevent stack overflow on ARM systems
2003-10-14* Make sure HUSH is initialized for running auto-update scriptsLABEL_2003_10_14_2140wdenk
* Make 5200 reset command _really_ reset the board, without running any other code after it * Fix flash mapping and display on P3G4 board * Patch by Kyle Harris, 15 Jul 2003: - add support for Intel IXP425 CPU - add support for IXDP425 eval board
2003-09-02* Add support for PPChameleon Eval Boardwdenk
* Add support for P3G4 board * Fix problem with MGT5100 FEC driver: add "early" MAC address initialization
